Fuel Accumulator test
RobertN
PostPosted: Tue Nov 17, 2015 8:49 am    Post subject: Fuel Accumulator test Reply with quote
Hi guys, can anyone advise on proper way to test my fuel accumulator, on or off car?
Loosing pressure when engine is left to sit after an hour, I'd turns and splutters a few times before starting. Once started you can switch off immediately and restart straight away!
Plenty of second hand accumulators from salvage yards, but would prefer to know if they actually work before buying. Also new is around £169.00!!!
Robert.
Robert.
Porsche 924 N/A 1984.
Electrical Engineering Sales to Control panel builders.
PostPosted: Tue Nov 17, 2015 10:17 am    Post subject: Reply with quote
Remove the slotted screw on the bottom, if fuel leaks out, its toast.
RobertN
PostPosted: Tue Nov 17, 2015 5:46 pm    Post subject: Reply with quote
Cheers Paul. Screw is seized completely. Tried lots of wd40 with no luck. The unit looks like it came from the Titanic!,
Robert.
RobertN
PostPosted: Tue Nov 17, 2015 8:37 pm    Post subject: Reply with quote
Paul,
Just wondering if I got one from a salvage yard would I be able to test it on the bench.?
Robert.
Robert.
PostPosted: Tue Nov 17, 2015 11:53 pm    Post subject: Reply with quote
That test would be done as follows:
Is the accumulator from the salvage yard?
If YES, then accumulator is bad.
In seriousness, bench test would require 100psi of fuel, although I guess a smoke test might reveal a leaking diaphragm.
RobertN
PostPosted: Wed Nov 18, 2015 12:32 am    Post subject: Reply with quote
was thinking of testing via an air pressure guage and compressing air into the unit and looking for a drop in psi? Seen this just now online!!
Robert.
jason c
PostPosted: Wed Nov 18, 2015 12:45 am    Post subject: Reply with quote
You don't new fuel or high pressure. High pressure is only needed to compress the spring, which never goes bad. You can test it with a leakdown type of test as you ask (if the bottom screw is removed).
You can also use a mityvac type vacuum/pressure tester. Plug one line & pressurize the other with the bottom screw removed.
Kenodog
PostPosted: Wed Nov 18, 2015 1:13 am    Post subject: Reply with quote
Put a torch on the screw, a little heat will get it loose.
Leigh
1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140
RobertN
PostPosted: Wed Nov 18, 2015 1:21 am    Post subject: Reply with quote
Hi Leigh.
Can you advise how to heat this while the unit is installed as I am nervous about applying a naked flame to the "fuel" accumulator??
Robert.
If you choose not to test it with real world pressure (can't imagine why you would)_ I would sure recheck it following installation.
PostPosted: Wed Nov 18, 2015 1:30 am    Post subject: Reply with quote
WD-40 is only a Water Displacer, it doesn't do much to help break up rust. Get a real rust treatment solution like PB Blaster. Heat helps, but not a great idea with fuel system stuff Percussion adjustments can help though!
jason c
PostPosted: Wed Nov 18, 2015 9:39 am    Post subject: Reply with quote
RobertN wrote:
Hi Leigh.
He is kidding, don't do that.
The diaphragm is rubber, it will leak at 1 psi if it is bad. A leak is a leak. Any leak is bad. Pressure is only needed to compress the spring, spring pressure is what compresses the fuel & thus maintains pressure while the system is idle. Since the spring doesn't go bad (the diaphragm is the only wearable part), high pressure isnt needed to test. The screw must be removed to test because the air leaking through the diaphragm will collect in the bottom portion, giving a false reading.
PostPosted: Wed Nov 18, 2015 12:31 pm    Post subject: Reply with quote
remove screw
place in vise upside down
borrow your kids soap bubbles
apply over the hole the screw was in
block the outlet, your finger will do
apply about 10 psi of air to the inlet
if you see bubbles, toss it...
