newbie924
Joined: 16 Mar 2016 Posts: 104 Location: EUROPE MALTA
Posted: Mon Mar 21, 2016 9:14 pm Post subject: Location of 924 NA engine number |
Can someone direct me to where the engine number is on the 924 2Lit block, I found a number on a 1979 year model which is found at the top right corner (photo) which is 046103921A,, not sure if this is it since details found on the internet state that it should have XK followed by 6 digits,,, either Im going blind or somethings wrong since Iv looked at the engine block and no such letters and numbers exist.
The number I have noted is found right above the silver/grey water pipe attached to the side of the block on the top right side |
Posted: Tue Mar 22, 2016 2:46 am Post subject: |
Look below the silver coolant pipe, about center in the picture you posted. _________________ Stefan
newbie924
Posted: Tue Mar 22, 2016 4:44 am Post subject: |
| fiat22turbo wrote: | | Look below the silver coolant pipe, about center in the picture you posted. |
Will do fiat,,, merci.... |
Posted: Tue Mar 22, 2016 8:18 am Post subject: |
See where the piece of blue masking tape is in the lower right of this image? That's where the engine code should be stamped. _________________ erstwhile owner of just about every 924 variant ever made |
newbie924
Posted: Tue Mar 22, 2016 7:45 pm Post subject: |
| Will do.. didnt look there for some reason, merci to both of you. |
newbie924
Posted: Sun Mar 27, 2016 12:34 am Post subject: |
| Found the engine number exactly were indicated.. number is XJ002316.. is there any way that I can check if this engine number is the original engine number as from new? |
Posted: Sun Mar 27, 2016 1:55 am Post subject: |
That information might be in the "PET," the Porsche parts catalog.
You can download it for free from Porsche.com.
It won't tell you if the motor left the factory in that car, but it will tell you if it is the right year. _________________ Toofah King Bad
newbie924
Posted: Sun Mar 27, 2016 2:11 am Post subject: |
| Rasta Monsta wrote: | That information might be in the "PET," the Porsche parts catalog.
It won't tell you if the motor left the factory in that car, but it will tell you if it is the right year. |
Thanks mate.. next thing to do. |
