Duncan
Joined: 04 Nov 2002 Posts: 425 Location: Delft, The Netherlands
Posted: Fri Sep 11, 2015 5:31 am Post subject: compression measuring procedure |
I recently bought a compression tester and would like to use it.
Some parts of the procedure are not completely clear to me:
As I understand now I should
1) run the engine until oil is at working temp 80+ celsius.
2) remove all spark plugs from the (hot) engine.
3) measure compression for each cylinder
4) wait for engine to cool down
5) refit spark plugs in cold engine with the correct torque.
In the compression tester manual it is suggested to take out the spark plugs one at a time and replace them in the hot engine. That does not seem to be a clever idea, or is it?
Best,
Duncan _________________ 1983 NA Alpineweiss since 2001
Peugeot 205 Generation |
Posted: Fri Sep 11, 2015 2:10 pm Post subject: |
I would add:
Remove fuel pump relay prior to testing
Crank with throttle wide open
As for reinstalling the plugs? Phht. . .however you want. _________________ Toofah King Bad
