Ian89C4
Joined: 01 Apr 2011 Posts: 561 Location: North Carolina
Posted: Wed May 18, 2011 9:09 am Post subject: Rod Bolts |
Gents,
I am very sure that I have to replace them on a rebuild, but so far all I have been able to source are the rod bolt nuts, even Porsche has a limited quantity of those.
Questions: Where can I source new rod bolts?
I tried through Pelican and another wholesale Porsche parts dealer and they said that Porsche was out. I have tried everywhere, but no luck. I have not tried DC auto, due to the fact that if they have to order them he will likely have a as hard a time as I.
Car will be a race car......so any leads towards ARP or Raceware would be awesome.....couldn't find any of those either.
Thanks,
Ian _________________ Ian Edgerly
North Carolina
Current:
1980 924 Euro ("Wahala") |
StienbargerR
Posted: Wed May 18, 2011 9:49 am Post subject: |
I think ideola can help you with finding a set. I think I saw on his website that he is able to get them, but supply is limited.
garage.ideola.com is the website.
Ryan _________________ 1978 924 NA
-250lb lowering springs, Euro Pistons |
Martijnus
Posted: Wed May 18, 2011 7:20 pm Post subject: |
You can get ARP ones, but you're certainly not obliged to replace them when rebuilding. I'd only replace them if they have visible damage or you know they have been stressed.
Remember that rod bolts are important when going high in revs... the valve train probably dies faster than the rod bolts. _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
the_mad_electrician
Joined: 16 Nov 2009 Posts: 1073 Location: Central Georgia
Posted: Wed May 18, 2011 8:14 pm Post subject: |
| Martijnus wrote: | | You can get ARP ones, but you're certainly not obliged to replace them when rebuilding. |
I was under the impression that they were not reusable. _________________ 81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6 |
Ian89C4
Posted: Thu May 19, 2011 12:33 am Post subject: |
I probably could leave them in there and just replace the nuts, but the line next to the rod bolt in the shop manual says "always replace" - and I think if I don't it will haunt me every time I take that car out on the track. Agreed though that the valve train will wear out faster.
I know on the 911's the rod bolts are designed to stretch quite a bit and they require 2 torque downs to achieve that. The shop manual for the 924 says it only needs one at 43 ft/lbs but I don't think I am going to chance it.
Thanks for the feedback  _________________ Ian Edgerly
North Carolina
Current:
Posted: Thu May 19, 2011 1:05 am Post subject: |
If you want to follow the instructions in the FSM (I know, who would?), they should be replaced. _________________ Toofah King Bad
Martijnus
Posted: Thu May 19, 2011 2:03 am Post subject: |
They aren't 'stretch' bolts (or whatever they're called), so replacing them everytime you loosen the nuts is bs.
Which manual is exactly the one that says this? If it is the original porsche one, I can understand they are NLA
Remember that manufacturers have a win-win situation by mentioning such stuff... they sell their parts, and they can't be held responsible if a rod bolt would fail, no matter how slight the chance is.
Some engines do require replacement of rod and main bolts though... but there aren't many.
Edit: I see Ian already mentioned stretch bolts they indeed combine torque + angle. _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
Posted: Thu May 19, 2011 2:30 am Post subject: |
They do indeed stretch on install, and the Factory Service Manual (printed long before the parts were NLA) says they are not to be reused.
I appreciate your cynicism, but given the diffculties getting bearings, etc, for these motors these days, it seems like a foolish risk to take. _________________ Toofah King Bad
gla924sem
Joined: 08 Nov 2002 Posts: 405 Location: Taylor, Michigan
Posted: Thu May 19, 2011 2:31 am Post subject: 924 |
| I think I got Ideola's last set |
Ian89C4
Posted: Thu May 19, 2011 5:06 am Post subject: |
Nope, I just got them  _________________ Ian Edgerly
North Carolina
Current:
Martijnus
Posted: Thu May 19, 2011 6:58 am Post subject: |
| Rasta Monsta wrote: | They do indeed stretch on install, and the Factory Service Manual (printed long before the parts were NLA) says they are not to be reused.
I appreciate your cynicism, but given the diffculties getting bearings, etc, for these motors these days, it seems like a foolish risk to take. |
heheh. Well I'm replacing them by ARP ones too in my turbo engine.
But just for statistics; how much threads are there on this board on broken rod bolts? _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
Posted: Thu May 19, 2011 7:00 am Post subject: |
| Martijnus wrote: | | But just for statistics; how much threads are there on this board on broken rod bolts? |
That's not the only failure mode one should be concerned with, nor is anecdotal evidence on this or any other forum justification for failing to follow FSM-recommended repair practices... _________________ erstwhile owner of just about every 924 variant ever made |
the_mad_electrician
Posted: Thu May 19, 2011 7:04 am Post subject: |
| Ian89C4 wrote: | Nope, I just got them  |
Damn I'm going to need some come winter! _________________ 81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6 |
Martijnus
Posted: Thu May 19, 2011 8:04 am Post subject: |
| ideola wrote: | | Martijnus wrote: | | But just for statistics; how much threads are there on this board on broken rod bolts? |
That's not the only failure mode one should be concerned with, nor is anecdotal evidence on this or any other forum justification for failing to follow FSM-recommended repair practices... |
What you're saying is that FSM recommendations are always the best, no matter what happens in practice? _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
Posted: Thu May 19, 2011 9:15 am Post subject: |
FSM comes from the factory engineers, who specified the materials used for EVERY FASTENER ON THE CAR.
Smarter than Stuttgart? By all means, ignore the manual. . .but don't try to convince others to do the same. _________________ Toofah King Bad
