Tigger937
Joined: 11 Apr 2004 Posts: 919 Location: PCA Milwaukee Region
Posted: Mon Jul 14, 2014 2:17 am Post subject: Help!!! A/C Stopped working |
Turned on A/C and nothing. Compressor won't engage, A/C fan won't even run. Prior to this, was working fine with good cooling. Heater fan continues to operate normally, no problems there. Where's the best place to start looking? _________________ 1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box" |
Posted: Mon Jul 14, 2014 3:45 am Post subject: |
Most of us are unfamiliar with working A/C units~! Check relays and fuses. _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
D Hook
Posted: Mon Jul 14, 2014 7:45 am Post subject: |
I've had problems in the past with the relay under the dash. That usually stops everything, not just the compressor. I'd start there.
Mine went out on a very hot day and I let it go for about 14 years, never bothered to replace the relay. Finally got one and put it in and it was still ice-cold A/C! _________________ '80 924 n/a SOLD |
Tigger937
Posted: Mon Jul 14, 2014 8:12 am Post subject: |
Thanks for the suggestions guys. D Hook, that's amazing it still cooled after 14 years. I would have thought the seals would have dried out and leaked out all the refrigerant. Is that relay accessible without dash removal? _________________ 1981 931 (Concours)
D Hook
Posted: Mon Jul 14, 2014 8:15 am Post subject: |
Yes, it's under the dash with the other relays. Don't recall which one it is though. Do you have a Haynes manual? _________________ '80 924 n/a SOLD |
Tigger937
Posted: Mon Jul 14, 2014 8:20 am Post subject: |
Yes, got a Haynes manual. Will check it out. Thanks much. _________________ 1981 931 (Concours)
D Hook
Posted: Mon Jul 14, 2014 8:23 am Post subject: |
When you find it, get a number from it and I'll check to see if I have one. Sell it cheap. Last time I priced one it was about $60 but that was quite some time ago. _________________ '80 924 n/a SOLD |
Tigger937
Posted: Mon Jul 14, 2014 8:35 am Post subject: |
Sounds good, I'll let you know. _________________ 1981 931 (Concours)
Tigger937
Posted: Mon Jul 14, 2014 2:48 pm Post subject: |
You were right, it's the relay p/n 477959143.
I noticed that area of the fuse/relay panel gets pretty hot, especially when A/C is on. Looking at the fuse/relay panel in the Haynes Manual p. 237, relays 2,3 & 6 are the fan, fuel pump & A/C relays respectively. When A/C is on, that area of the panel is drawing quite a bit of current. Mine has 2 fans and 2 fuel pumps in addition to the A/C. Seems the heat in that area could be contributing to shortened relay life? Anyone ever look into this? _________________ 1981 931 (Concours)
D Hook
Posted: Mon Jul 14, 2014 9:55 pm Post subject: |
You're right. I've had the same experience with the heat issue. I'm sure it contributes to the failure rate of the fuel pump and A/C relays both. I even thought of installing a computer-type small fan to cool them. Keeping the grounds clean helps a great deal.
I'll check and see if I have that relay.
EDIT: I guess I don't have one. Sorry. But I bet Dan (Ideola) has one or more. Also might want to put a note on the For Sale/Wanted board because so many people have removed their A/C systems for saving weight, there's probably plenty floating around out their. I'd grab a couple, if I were you. And maybe a spare fuel pump relay to keep in the glove compartment.
Here's a website that sell NOS A/C relays. http://classicgarage.com/477959143.html _________________ '80 924 n/a SOLD |
Posted: Tue Jul 15, 2014 4:30 am Post subject: |
I have one of those relays, original. _________________ '83 944 Track car.
Tigger937
Posted: Tue Jul 15, 2014 3:58 pm Post subject: |
Thanks Grenadiers. I had some new replacement relays lying around, p/n 94461511301 which is supposed to be the newer equivalent of 477959143. Seems to be working OK. _________________ 1981 931 (Concours)
