brian19600
Posted: Mon Dec 02, 2013 10:57 pm Post subject: blower motor |
I am currently working on replacing the blower motor on my '78 w/ac. Only one place seems to have a used one. I thought about using a 7" radiator fan, since we are trying to blow air through a "radiator" (heater core).
Anyone ever try that? I'm sure the air flow would be excellent!
Has anyone modified the heater box? It seems inefficient that it can't blow directly onto the core, but has to go through a hairpin turn. I would love to remove the barrier between the blower wheel and the core, but I'm not really certain of air handling technology. _________________ 78 924 |
dubrict
Joined: 22 Apr 2011 Posts: 150 Location: Horseheads NY
Posted: Tue Dec 03, 2013 7:43 am Post subject: |
the turn might make more turbulence, but it's not less efficient. Think of it like putting an elbow on a water pipe, you won't lose any pressure.
I would say the stock unit would be better than a small radiator fan on the core because it sucks the air straight from the top and forces it down to the core.
I have a blower motor from a '77 if you need one, send me a PM _________________ 1979 924 NA
2009 Chevy Impala
2005 Dodge Dakota |
brian19600
Posted: Tue Dec 03, 2013 10:39 pm Post subject: blower |
Does the stock blower work fairly well? Based on what I've read so far, it doesn't seem to do much.
I also PM'd you. _________________ 78 924 |
SilverGhost
Joined: 16 Mar 2011 Posts: 56 Location: Melbourne, Australia
Posted: Wed Dec 04, 2013 8:58 am Post subject: |
The stock blower is barely useful. Its the weakest blower on any car I've ever owned. _________________ "Priscilla" 1981 924 NA RoW auto, metallic blue |
brian19600
Posted: Wed Dec 04, 2013 9:21 am Post subject: blower |
So other than doing the 944 heater box conversion, would a more powerful blower help? _________________ 78 924 |
brian19600
Posted: Wed Dec 04, 2013 11:58 pm Post subject: blower |
I've been doing some experimentation. I have a mid 90's gm blower motor with a blower wheel that i placed in the heater box. Little to no output. Now the rotation (clockwise) may not be the same as the original based on the baffles I see in there. But it still should be pressurizing the box the same way.
Now I had a 4" low output computer muffin fan that I placed on top and tried. Air came out!! If it was a high output fan I would be all set.
What I believe to be the case is that a blower wheel (which is supposed to be more efficient than a fan blade) is not the proper way to move air in this particular designed box. A fan blade would work better.
thoughts? _________________ 78 924 |
Posted: Thu Dec 05, 2013 12:26 am Post subject: |
I'm confused... what do you mean blower wheel vs. fan blade? Fan blade as in the original style, blower wheel like the squirrel-cage style? _________________ Vaughan Scott
brian19600
Posted: Thu Dec 05, 2013 12:45 am Post subject: blower |
Yes, the non a/c cars used a fan blade and the a/c equipped cars used a blower wheel. _________________ 78 924 |
Posted: Thu Dec 05, 2013 1:10 am Post subject: Re: blower |
| brian19600 wrote: | | Yes, the non a/c cars used a fan blade and the a/c equipped cars used a blower wheel. |
Nope.
Cars with A/C have two fans, one for fresh air + heat (fan blade style), and one for A/C (blower wheel style).
The fresh air fan sits in the cowl area, and this is the one you need to replace. The A/C fan is contained in a separate plenum and is routed such that it doesn't blow over the heater core, only the evaporator within the A/C plenum.
The only 924 that ever came with blower wheel style fan for the heat is the very late VINs in the 1982 model year (and presumably the 1983-onward models for ROW markets). This setup is the same as in the 944/924S and requires sheet metal modification to retrofit into the early chassis. _________________ erstwhile owner of just about every 924 variant ever made |
brian19600
Posted: Thu Dec 05, 2013 1:31 am Post subject: blower wheel |
Nope. At least with the '78s with a/c (M573) , they only had one fan motor w/ a blower wheel. Refer PET illustration 813-20.
There is a flap next to the battery that gets opened to suck the cold air out of the evaporator assembly and down into the heater box for distribution.
A dismal sounding setup.  _________________ 78 924 |
Posted: Thu Dec 05, 2013 7:46 am Post subject: Re: blower wheel |
| brian19600 wrote: | | Nope. At least with the '78s with a/c (M573) , they only had one fan motor w/ a blower wheel. Refer PET illustration 813-20. |
Damn early cars! Always some undiscovered permutation! I stand corrected. _________________ erstwhile owner of just about every 924 variant ever made |
brian19600
Posted: Thu Dec 05, 2013 7:57 am Post subject: blower motor |
LOL I wish it did have 2 blowers. From what I understand now, the heater motor was poor at best and then it has to suck conditioned air from 4' away.
Were they under pressure to keep development costs down?
On a different note ideola, do you still have that manual radio antenna for sale?
thanks
brian _________________ 78 924 |
Posted: Thu Dec 05, 2013 10:47 pm Post subject: |
That truly is a wierd setup. My guess is they were trying to improve on the first setup, which was lame; I think in a properly-designed airbox the squirrel cage/hamster wheel flows better, but you've hit the nail on the head and they cheaped-out and didn't include the box redesign it needed.
IIRC the later, successful implementation of the wheel used them oriented in the vertical plane, blowing downward into the box, same orientation as the fan blade style.
It's especially telling, to me, that they reverted to the fan blade in '79...
I still would love to see a revision/upgrade to this, as my '82 931 still has the crappy fan blade. _________________ Vaughan Scott
brian19600
Posted: Fri Dec 06, 2013 12:05 am Post subject: blower |
Yeah I can't understand why they went with a blower wheel instead of a fan with the a/c version. By the way, this 77-78 924 setup is also on a 74-77 Dasher w/ac.
I would have thought with the German winters, the heat would be the best thing on the car. Maybe the heat output from the beetles (or even worse the vw buses) desensitized the people to what good heat is.
I just ordered a jumbo muffin-like fan I'm going to try. _________________ 78 924 |
Julian
Posted: Sun Dec 08, 2013 11:01 am Post subject: |
| I used the blower fan from a 911. I had to turn the shaft down a little and shorten it a bit. I have the part number in the shop if interested. Worked fine in my 78. |
