K&N Intake Kit for 924 non-turbo
tscharke
PostPosted: Tue Oct 29, 2013 10:17 am    Post subject: K&N Intake Kit for 924 non-turbo Reply with quote
Hi
K&N list an intake performance kit for the 924 2.0 turbo but I am wondering if this kit would be suitable for a 2.0 non-turbo? Can anyone confirm that it would fit?
http://www.knfilters.com/search/product.aspx?prod=57-0112
Many thanks
Scott
PostPosted: Tue Oct 29, 2013 1:33 pm    Post subject: Reply with quote
Won't help very much. The CIS fuel distributor and throttle body are bigger restrictions.
You'd be better off providing cool, fresh air to the stock intake snorkel.
tscharke
PostPosted: Tue Oct 29, 2013 2:03 pm    Post subject: Reply with quote
many thanks for the honest advice mate, I appreciate it. There seems plenty of room to add a cold air induction snorkel and maybe even make a hole in the front nose. Cool, another addition to the long list of "to-do's"
By chance has anybody built a cold air induction system for the 2.0 non-turb and have any pointers?
thanks all - I only bought my first 924 3 weeks ago and I am growing a healthy addiction to it already
PostPosted: Tue Oct 29, 2013 3:08 pm    Post subject: Reply with quote
Some of the 944 folks have installed a NACA duct into the headlight bucket cover and then sealed off the area behind the headlight.
I cut ally have one that has been modified already, it looks pretty simple to do if you're willing to mess with a cutting saw and fiberglass work.
Another thought is to simply run a hose down through the area behind the headlight bucket with a snorkel on the end open the air inlet near the radiator.
tscharke
PostPosted: Tue Oct 29, 2013 6:45 pm    Post subject: Reply with quote
love ya work - thanks mate. I like the sound of cut'n'glass a homemade version!
Cheers
Scott
PostPosted: Wed Oct 30, 2013 7:43 am    Post subject: Reply with quote
This might help:
http://sfbay.craigslist.org/nby/pts/4150939375.html
Way overpriced, but other early Audi and VW TB's will fit as a cheaper upgrade (or perhaps if you're handy with metal fab, you could build an adapter to use a more common round TB)
tscharke
PostPosted: Wed Oct 30, 2013 9:02 am    Post subject: Reply with quote
geez, does it really give that amount of increased performance?
thanks for the tip - I going to do my research
Cheers
Scott
tscharke
PostPosted: Thu Oct 31, 2013 10:34 am    Post subject: Reply with quote
apologies for the double post
I noticed thay the "Porsche 924 VW Rabbit Scirocco TB300 Weber throttle body" allows for an extra long throttle shaft allowing micro-switch actuation of Nitrous Oxide and/or water injection. Would a stock setup handle a small amount of NoS or would it jusy go BANG
1981 Porsche 924 2.0 NA
ThomasJoseph315
Guest
PostPosted: Mon Nov 04, 2013 7:20 am    Post subject: Reply with quote
You can those parts at an auto parts store for a lot less then the price of a K&N kit. They will be another brand though, it's not like your buying a chrome metal intake, or even a hard plastic housing.
