ditch68
Posted: Sat Sep 14, 2013 5:16 am Post subject: Emissions difficulties on 1979 N/A |
Well, I have failed emissions. 4 times.
What I have done:
Plugs, cap, rotor, pulled injectors and ran brake cleaner through them with the red stick, the cone pattern is perfect and atomizes correctly. Checked my WUR, there was a cut wire at the connector, but that made no improvement in emissions, but really improved the way the car ran! Seafoam is something I use on all my cars. I also run Shell gas, not cheap Circle K crap.
I attempted the adjustment of the air/fuel mixture at the fuel distributor next, in concert with the idle screw on the throttle body. I have a nice, smooth idle at 800 rpm.
All the car needs here is an idle test being a '79. Basically it is running way too rich (high HC) and CO is very low Way under passing levels.
I seem to have misplaced my test result sheet. I'll keep looking for it and report those numbers.
Jeff _________________ Current:
1979 924, all stock.
1988 951 all track modded out and angry.
Past: 1986 951, 1988 924S, 1965 912 with '69 911T engine. |
ThomasJoseph315 Guest
Posted: Thu Oct 24, 2013 2:07 am Post subject: |
I spent $400 on testing fees as I am from NY and hadn't a clue about CA emission laws.
Biggest factors for me:
Replace your cat, either mine was punched out, or it burned it's self through. Either way it was completely hollow. It was kinda impressive actually if someone scrapped it it was completely gone. I put a magnaflow converter on my 924 and it ran so clean 0.0% Co we had to richen it up to reduce NO2.
Find a testing facility that has a dyno, and put it on a test dyno to tune your air/fuel mix. There is absolutely no way you will ever tune this by yourself to pass emissions so save yourself some money and just pay someone to do a test n tune.
My EGR was connected, but I don't think it did anything. Their supposed to do something with the NO2 but who the hell knows. I made another post about how they fumbled the intake and that metal ring inside it is supposed to increase the vacuum but never opens. I tried cleaning mine out with brake cleaner and such,.. it was a waster of time.
The primary part of an emission test is to make sure your burning fuel at the right rate. The fuel distributor is so sensitive when you tun the 3mm allen wrench you can easily over shoot it.
Yes, do all the normal stuff, change plugs wires, oil change. If your car was sitting for any length of time you may need to put some good gas in it and run it for a few weeks before you notice that the idle smooths out.
Also,.. when they tune it to pass emission, my car would idle like crap and he had to really work the gas to keep it alive. He finally got it to pass.
Hope this helps!  |
Posted: Thu Oct 24, 2013 2:09 am Post subject: |
The primary part of an emission test is to make sure your cat is working and your burning fuel at the right rate. The fuel distributor is so sensitive when you tun the 3mm allen wrench you can easily over shoot it.
Oh hot tip! Check your performance of your cat with a laser,..
http://www.youtube.com/watch?v=9VZ5K8n5jj0&noredirect=1
Hope this helps!  |
