Help, brake fluid change - no flow from passenger side
porsche_reg
PostPosted: Mon Feb 20, 2017 7:11 am    Post subject: Help, brake fluid change - no flow from passenger side Reply with quote
hey all - I'm changing my brake fluid ('79 n/a), it's a been a bit, but not more than a few years. Everything was going fine (I've never done myself before) with fluid flowing from passenger side just fine, then on to the drivers side.
Fluid was pretty dirty, could see grit in there. Also the reason I'm changing (other than something to do and learning to do it myself) is that during the winter (worst winter in Boise I've ever seen with single digits and snow since Dec, now it's like spring though) I had some soft pedals. I could re-pump and pressure would return.
So now I'm trying to refill and get all the air out, but the passenger side only isn't flowing again. So I'm unable to return the car to service. I can build pressure up with a pump (Schwaben pressure bleeder) and it flows air and some spittle of fluid, but doesn't build or flow normally...
Any ideas or recommendations? I'd suspect if it was a bad master cylinder nothing would have some from the drivers side.
Thank you in advance.
Prev: '81 BMW 320i
'05 997.1 C2
Current: '79 924 n/a (family owned since new)
'12 Subaru Outback
Ozzie
PostPosted: Mon Feb 20, 2017 7:17 am    Post subject: Reply with quote
Sounds like an overhaul of the system is required.
Any dirt or grit will damage seals and something akin to snot builds up in the pistons.
there are small ports in the MC and one could be blocked
Its AUTO and its BLACK
Montego Black on black/red
porsche_reg
PostPosted: Mon Feb 20, 2017 7:31 am    Post subject: Reply with quote
dang it...
Prev: '81 BMW 320i
'05 997.1 C2
'12 Subaru Outback
porsche_reg
PostPosted: Mon Feb 20, 2017 7:47 am    Post subject: Reply with quote
thanks Ozzie, when you say rebuild, just the master cylinder or do I need more?
I'm finding a wide range of prices. Stoddard has 477-611-015-A Master Cylinder for <$150, others are showing $200 - $300. Those might be for M471 options though.
Prev: '81 BMW 320i
'05 997.1 C2
'12 Subaru Outback
PostPosted: Mon Feb 20, 2017 8:06 am    Post subject: Reply with quote
First I'd take the break lines and resivoir off of the MC, brake lines off calipers, blow all the lines out, throw a rag over the MC and blow it out from the lines inputs etc.. Compressed air ofcourse..
Then put the MC back together and fill it up, walk around the car like duck duck goose putting the lines back on he calipers once fluid was dripping from them nicely. Let it gravity bleed like that untill all are back together then pump the brakes bleed them and see what you get..
porsche_reg
PostPosted: Mon Feb 20, 2017 8:38 am    Post subject: Reply with quote
thanks Fasteddie, good idea!
Prev: '81 BMW 320i
'05 997.1 C2
'12 Subaru Outback
PostPosted: Mon Feb 20, 2017 9:13 am    Post subject: Reply with quote
A couple likely possibilities on one caliper are that the rubber hose is swollen and clogged or the foot of the bleeder screw inside the caliper is clogged with rust.
1981 924 Turbo sold
1982 924 Turbo sold
porsche_reg
PostPosted: Mon Feb 20, 2017 9:42 am    Post subject: Reply with quote
I tested the line out to the hard metal lines connecting to the rubber ones connecting to the actual brakes - only air came out with the pressure pump.
Master cylinder was removed (I'm not that familiar with the workings, but looks pretty simple) and the front two ports or holes were pumping fluid when I pushed the pump, the back single port spurted a little, but not flowing like the front ones.
This leads me to believe something is wrong with the MC along the way.
Prev: '81 BMW 320i
'05 997.1 C2
'12 Subaru Outback
Ozzie
PostPosted: Mon Feb 20, 2017 12:29 pm    Post subject: Reply with quote
Master cylinder kits are available.
I have a Girling kit here but it is for a smaller diameter bore (19mm?) than mine which is larger. (22mm?)
Scott Sanda
PostPosted: Tue Feb 21, 2017 8:03 am    Post subject: Reply with quote
Pardon me if this question is insulting, it is not meant to be. Did you re fill the brake fluid reservoirs?
The only way you are going to get air out of a bleed valve if you have positive pressure on the top of the reservoir is if it is empty. If there was a leak upstream to the caliper, you would not get air from the valve, you would have fluid squirting out somewhere else.
I've accidentally pressure bled a race car dry before. You need to stop frequently, remove the air source, and top up the res.
Again, apologies if you have been refilling, and don't kick yourself too hard if you have not.
porsche_reg
PostPosted: Tue Feb 21, 2017 8:33 am    Post subject: Reply with quote
Hi Scott - no insult taken, sometimes the most obvious things are overlooked and it takes another to see it.
But yes, I did have the reservoir refilled. The drivers side bleeder was letting fluid flow, just the passenger was not. Air would flow through the lines fine, which led me to believe the original recommendation from Ozzie (overhaul) is the right course of action. New one on the way from Stoddard (paid a pretty penny to get it here overnight...)
Prev: '81 BMW 320i
'05 997.1 C2
'12 Subaru Outback
PostPosted: Tue Feb 21, 2017 8:36 am    Post subject: Reply with quote
Rubber brake hoses should have a date on them, replace when 10 years old.
porsche_reg
PostPosted: Wed Feb 22, 2017 12:28 pm    Post subject: Reply with quote
thanks Paul, certainly could be a problem... I have received the MC from Stoddard (kudos to them for the NDA, got it today!)
Now, next problem is the seal to the booster - need an o-ring, but somehow I got 911-355-922-00 which apparently is for the reservoir (but not a 924 one).
Prev: '81 BMW 320i
'05 997.1 C2
'12 Subaru Outback
porsche_reg
PostPosted: Wed Feb 22, 2017 12:45 pm    Post subject: Reply with quote
hey Paul, any thoughts on where to source the brake lines? Looks like most of them are for five lugs, I'm at 4.
I see Ideola has the Goodridge, but I'm trying to stay a little under that price wise. I'm sure they are very nice.
Thanks,
Prev: '81 BMW 320i
'05 997.1 C2
'12 Subaru Outback
PostPosted: Wed Feb 22, 2017 1:50 pm    Post subject: Reply with quote
Front ones here:
http://www.autohausaz.com/pn/477611071A
I also checked Sunset they want $83 each:
http://www.sunsetporscheparts.com/?p=catalog&mode=search&search_in=all&search_str=477611071a
