Bockscar
Joined: 16 Nov 2010 Posts: 392 Location: Sandy, Oregon
Posted: Sat Mar 09, 2013 2:26 pm Post subject: Replacement for S1 charge tube sleeve |
Is there a non-oem replacement part for part #931 110 157 02, the rubber charge tube sleeve for an S1? The closest thing that I've found is an over-sized rubber sleeve with a hole in the middle for some kind of sensor for a VW. _________________ Brian
'79 924 - Restoration In Progress
'81 924 Turbo w/EFI - Scrapped |
Posted: Sat Mar 09, 2013 4:23 pm Post subject: |
Throw it all away, switch to S2 manifold. _________________ Toofah King Bad
Bockscar
Posted: Sun Mar 10, 2013 4:13 am Post subject: |
| Rasta Monsta wrote: | | Throw it all away, switch to S2 manifold. |
Switching to the S2 setup would involve a tremendous effort for very little gain. I'd rather just source a simple oval coupling to put around the throttle body and manifold and call it good. However sourcing said coupling is proving to be a challenge. _________________ Brian
Posted: Sun Mar 10, 2013 5:23 am Post subject: |
That's odd, I would call it minimal effort for appreciable gain, but good luck with the windmills! _________________ Toofah King Bad
Bockscar
Posted: Sun Mar 10, 2013 5:38 am Post subject: |
| Rasta Monsta wrote: | | That's odd, I would call it minimal effort for appreciable gain, but good luck with the windmills! |
Anything that separates me from OEM Porsche parts is a gain, I say. For example, I am using a throttle body from a MK 2 VW Jetta. Why? Because Porsche parts are nearly impossible to obtain. My oil cooler kicked the bucket so I replaced with with another VW part. I see no benefit from owning a 924 and sticking with OEM parts. _________________ Brian
Posted: Sat Apr 06, 2013 3:53 am Post subject: |
Why not just calculate what size diameter the ovoid coupler would be if it was a circle, and then order a section of suitably sized silicone? Silicone is flexible enough to be compressed into the ovoid shape you need using the OEM (gasp!) band clamps for the OEM boot. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Sat Apr 06, 2013 4:08 am Post subject: |
BTW, the I think Rasta was trying to say that swapping to the S2 charge tube and intake would get you a round opening at the throttle body end with which to couple to (both of which is mostly the same as the S1 except for the throttle body opening and mounting). If your throttle body is also already round and not oval then even better.
The S2 throttle body is rebuildable to reduce/eliminate leaks, etc., while the S1 isn't (at least it isn't worth the effort it seems)
Either way, a piece of string around the oval ports would get you the circumference which could then be converted into diameter via simple math and allow you to determine the closest round reinforced rubber or silicone hose section. Large truck service shops (big rig) typically have really nice reinforced rubber radiator hose in very large diameters and you could see if there was any excess laying around they would give you/buy. My brother did this for one of his turbo cars and that hose was impressive in its strength to say the least.
Or you could ditch the stupid charge tube and add an intercooler, but that would be a lot more work to adapt (on the turbo side mostly is seems), but would gain you quite a bit more in the long run. _________________ Stefan
