Posted: Mon Oct 06, 2014 7:31 am Post subject: |
Looks good. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
Joined: 05 Jun 2006 Posts: 1475 Location: Ontario, Canada
Posted: Thu Jul 16, 2015 10:38 am Post subject: |
Since I pulled her out of the garage this spring, I did:
-4 wheel alignment
-installed O2 sensor for my wide band A/F ratio
-convert to S2 Throttle body
-installed a new fuel level sending unit
-installed second tail light bulb
-leak/smoke test
-fix the rear exhaust
Once I'm confident that everything run well, I will raise the boost from 10 to 12lbs. _________________ 1976 924 N/A ROW SOLD
1980 931S
1981 931 Part car RIP |
SlayerSST
Posted: Thu Jul 16, 2015 10:54 am Post subject: |
You will be fine. Currently running 15psi no intercooler. |
Posted: Thu Jul 16, 2015 10:34 pm Post subject: |
SlayerSST wrote: | Currently running 15psi no intercooler. |
Interesting
On a stock engine?
S1 or S2? _________________ 1976 924 N/A ROW SOLD
1980 931S
Posted: Thu Jul 16, 2015 10:45 pm Post subject: |
Claude, I missed your photos earlier. The car looks amazing! So nice to see projects coming to fruition!!!
With my new job, I won't have much opportunity to get to Ottawa any more, but man, wish we could get on some back country roads with a couple of the cars...would be so nice to do some comparisons. Let me know if you are ever able to consider a road trip to the Chicago area, we'd be happy to host you here! _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Fri Jul 17, 2015 8:31 am Post subject: |
Thanks Dan,
I would love to visit you place and see all you car. I don`t think it would be possible this summer but will keep it in mind. _________________ 1976 924 N/A ROW SOLD
1980 931S
Posted: Mon Apr 25, 2016 8:26 am Post subject: |
2016 spring update
After spending/wasting the summer and fall last year fighting fuel delivery issue and low voltage, I pulled the engine out and ordered loads of parts. Here’s a list of what has been done since last fall:
-rebuilt WUR by CIS Flowtech
-new high output alternator from Ideola’s garage
-new fuel filter
-new spark plugs
-new fuel pump
-new fuel accumulator
-new 944 in-tank fuel strainer
-send the fuel tank for cleaning (was full of crap)
-completed S2 intake conversion
After all that she still run like sh!t, cutting off as soon as I start building boost; then I unplug the over-boost switch and ground the wire and then...she went like hell. Currently running 10lbs of boost, about 11 AFR at WOT.
The bad news, during all that work, I broke my windshield and my fibreglass hood in three pieces (please don’t ask..). On the + side, I will upgrade to 944 style flush windshield and I have fibreglass resin and cloth at home so I will be able to fix the hood.
Also, I pick up a great bolt in GTS style roll cage (with long bar reaching at the back) during the winter at a very good price. It will get strip and repaint flat black during the summer.
1980 931S
Posted: Sat Aug 06, 2016 8:43 am Post subject: |
I start working on the inside, insulate using EZ cool and re-carpeting using lightweight generic stuff. It’s far from perfect, but much better than the old stuff. I also installed a Rennline dead pedal.
Installed the 935/937 boost controller, relocated it in front of the shifter and increase the boost from 10 to 12 lbs. I have the same problem than other members; running too low Air/Fuel ratio under boost, so I will have to look into this.
I also modified the roll cage into a roll bare, deleting everything forward of the main hoop, painted it flat black and installed it. I love the look of the two long harms reaching the back of the car with the diagonal in between.
Next on the list, finish inside re-carpeting, transmission flange seals and brake.
1980 931S
Posted: Sat Aug 06, 2016 11:03 am Post subject: |
Lookin' good! and fast....!!!!! _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Mon Aug 22, 2016 8:48 am Post subject: |
Rainy day, so I play around with my new phone.
My favorite
1980 931S
gegge
Posted: Sat Mar 11, 2017 5:15 am Post subject: |
Very nice. Soon to be proper manifolded? _________________ Carl Fredrik Torkildsen
Posted: Mon May 01, 2017 5:22 am Post subject: |
Spring tune up:
-oil brake change
-install stainless steel brake lines
-engine oil + oil filter change
-coolant flush
-re-install battery
Pulled here out of the garage, start here up and went out for the first drive of the season. Woohoo! _________________ 1976 924 N/A ROW SOLD
1980 931S
Posted: Tue May 23, 2017 9:23 am Post subject: |
Give her a bath, followed by a light compound and wax
Picture taken after each step
1980 931S
Posted: Tue May 23, 2017 9:31 am Post subject: |
Let's see the whole car!!!!!!!!! _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Tue May 23, 2017 9:39 am Post subject: |
Well, I didn't had time to do the hood yet mainly because it needs some repair first...so...maybe next week-end _________________ 1976 924 N/A ROW SOLD
1980 931S
