My new project
Goto page Previous  1, 2, 3, 4 ... 13, 14, 15  Next
DOCO
PostPosted: Sat Sep 15, 2012 3:16 am    Post subject: Reply with quote
"That’s it, will give it a try over the week-end, but it also slow things down. "
Its very important to use Australian QUALITY beer... got to be cold and full strength...
Good idea BUT good canadian beer will handle that job no problem!!!! We do know how to make it over here!!!
Doco "where am i going and why am i in this handbasket"author unknown
79 924 N/A "Webster"
_______
/______\
[+]___[+]
\0 924 0/
[__]..[__]
"WEBB STR"
924-76
PostPosted: Mon Sep 24, 2012 1:39 am    Post subject: Reply with quote
Pull the engine out, what a PITA compare to the N/A engine.
I believe it time for a new clutch.
And everybody knows that electric tape is the best thing against vacuum leak, right!
1976 924 N/A ROW SOLD
1980 931S
1981 931 Part car RIP
924-76
PostPosted: Sun Mar 24, 2013 8:33 am    Post subject: Reply with quote
I finally got some time to work on my 931 project.
I pulled the head off today, planning on cleaning the carbon and reassemble within the next mount.
This will include:
APR head stud
3 layer MLS head gasket
NOS turbo S1 series
Rebuilt wastegate ready to receive the RUF 935 type boost controller
Stage 8 Exhaust locking nuts
Light weight adjustable cam gear
Bosch knock sensor for a used Turbo XS knocklite
Boost line for VDO boost gauge
Resurface flywheel
Rebuilt clutch
Resurface 915 Alu pressure plate
Hi-Torque starter
New plugs
New wires
New cap and rotor
K&N cone air filter
New oil filter
New belts
Replacing the air/fuel unit to turbo boot
Replacing Alternator
Removing the A/C and cutting bracket
And prepping for the 951 intercooler piping
1980 931S
PostPosted: Sun Mar 24, 2013 2:41 pm    Post subject: Reply with quote
Shit, if I would've seen this earlier I have a turbo rubber boot that is in perfect shape to replace the one you have with a leak.
924-76
PostPosted: Sun Mar 24, 2013 8:54 pm    Post subject: Reply with quote
No worries, I have a replacement one already.
Thanks
1980 931S
924-76
PostPosted: Mon Mar 25, 2013 5:43 am    Post subject: Reply with quote
Bad news, the crack is also visible from the inside
Can this be fixed or should I replace it?
1980 931S
PostPosted: Mon Mar 25, 2013 7:44 am    Post subject: Reply with quote
You can fix that, take small grinder, and groove the crack, then heat it in your oven to 500 degrees, and then weld it with a high nickel content arc welder rod. Then, put it in a box with sand on the bottom, then cover it with more sand, then forget about it for a few days as it cools. Many write-ups on this process on the board if you need more information.
924-76
PostPosted: Mon Mar 25, 2013 7:50 am    Post subject: Reply with quote
Thank you for the info
Now I need to find a good local welding shop
1980 931S
PostPosted: Mon Mar 25, 2013 8:09 am    Post subject: Reply with quote
Be careful there, the Porsche cast iron is a higher quality than most American manifolds that they might be used to. Don't let them MIG weld it for example.
924-76
PostPosted: Tue Mar 26, 2013 2:23 am    Post subject: Reply with quote
Sweet, I just found someone to fix my exhaust manifold.
He as done many and he is using the same process as described above.
1980 931S
924-76
PostPosted: Fri Apr 05, 2013 10:06 am    Post subject: Reply with quote
I picked up the clutch/ flywheel and 915 pressure plate from the shop at the end of the day with new release and pilot bearings.
Here’s some before and after shots:
Clutch disc:
Flywheel:
915 Pressure plate:
1980 931S
924-76
PostPosted: Thu Jul 25, 2013 10:01 pm    Post subject: Reply with quote
My latest ebay found for my GTS clone just came in the mail.
1980 931S
924-76
PostPosted: Tue Aug 06, 2013 7:00 am    Post subject: Reply with quote
How I plan to connect to the 951 intercooler
1980 931S
924-76
PostPosted: Tue Aug 06, 2013 8:38 am    Post subject: Reply with quote
Some body progress
-hood scoop
-944 fenders
-GTS front bumper
1980 931S
924-76
PostPosted: Thu Aug 08, 2013 2:19 am    Post subject: Reply with quote
Finally got some work done on the car this morning.
I removed 55lbs worth of crap, rotten under carpet from the front of the car and sticky rubber layer from the truck.
Also remove the non-working and unwanted A/C, 45lbs.
This stuff is free + shipping (unknown condition)
Then I loaded the front bumper with signal, driving light and modified 944 euro bumper rubber.
1980 931S
Page 3 of 15
