EFI conversion , using a jetta setup???? any input?
PORSHCE 924
PostPosted: Fri Sep 21, 2012 1:43 am    Post subject: EFI conversion , using a jetta setup???? any input? Reply with quote
ok idk if im crazy or not , but i was thinking of taking a mk3 jetta wiring harness and computer to convert my 924 to fuel injection, now I plan on getting the ecu tuned for a turbo so as everything will proper and hopefully run right. I was just wondering if anyone had any input or suggestions???
CorsePerVita
PostPosted: Fri Sep 21, 2012 3:45 am    Post subject: Reply with quote
You'll need a lot more than just a harness and ECU since you're on CIS. I haven't seen anyone use those components before. Most of the conversions I've seen have been megasquirt. Although it never hurts to try new things.
- 1977 Porsche 924 2.0 N/A (Trackday Project)
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS
ksis
PostPosted: Fri Sep 21, 2012 8:34 am    Post subject: Reply with quote
The mk3 ecu involves an alarm system that is a bear to get around. Check out my post under Easy EFI.
64 Spitfire
76 TR6
04 Jetta
77 Schwinn Scrambler
Awsome pair of Chucks
http://www.cardomain.com/id/ksiskin
