Look what I found
Joes924
PostPosted: Fri Jul 19, 2002 4:02 am    Post subject: Reply with quote
This stuff was in there just like that its the right side dash vent delivery tube,Ithink this stuf is meant to take out moisture or [absorb water] when it was leaken the previous owner put this stuff in side the car wonder how it got in the vent
check it out.
http://home.attbi.com/~joedanka/June924/inter4.JPG
awilson40
PostPosted: Fri Jul 19, 2002 4:16 am    Post subject: Reply with quote
looks like D-Con rat poison to me
wdb
PostPosted: Fri Jul 19, 2002 5:04 am    Post subject: Reply with quote
looks like rat poison to me too. this is serious joe,that stuff needs to be tested or you need blood work done to know for sure. signs and symptoms of pestiside poisoning
http://www.ianr.unl.edu/pubs/pesticides/ec2505.htm
ltgland
PostPosted: Fri Jul 19, 2002 5:46 am    Post subject: Reply with quote
from my farmer day, I can tell you its not Temic. That stuff is horrifically poisonous... I wouldnt go near the fields for 2 days after that stuff went down.
The farm workers used to walk there without their shoes on, and I would throw a wobbly over it. Fekk they could have got very badly poisoned, like "bleu"...dead.
Well, at least it doesnt lurk in the food chain....
81turbo
PostPosted: Fri Jul 19, 2002 8:02 am    Post subject: Reply with quote
hey joe do you have any dead rodents in the car to go with your fine collection of rat poison? If you do, you should remove them dead rodent = weight therefore dead rodents are bad. By chance can you think of anyone who may be trying to kill you? Seems like a slow death but hey what ever works. Does your girlfriend have a life insurance policy on you? just checking
[ This Message was edited by: 81turbo on 2002-07-19 09:11 ]
PostPosted: Fri Jul 19, 2002 9:31 am    Post subject: Reply with quote
Joe - When you bought the car, was this stuff sprinkled around the inside of the car? If it was, and the PO put it there, you can be pretty sure he also put it into the vent. If it is rat poison, it's time to notify the authorities and track that clown down...
JvGinPDX
PostPosted: Fri Jul 19, 2002 9:54 am    Post subject: Reply with quote
I doubt that rat poison would be put in to air tubes. But dehumidifier crystals would be, if some misguided person wished to clear a foggy windshield.
dwak
PostPosted: Fri Jul 19, 2002 9:58 am    Post subject: Reply with quote
It's all very clear to me. 924= rat nose. PO was trying to get rid of the car's rat nose.
Just my desiccant form of humour.
dwak
wdb
PostPosted: Fri Jul 19, 2002 11:27 am    Post subject: Reply with quote
hey I had an idea, go to a pet store buy a rat for $2.oo ( they are cheap, snake food ) and feed It too the rat and see how it he does.
Joes924
PostPosted: Fri Jul 19, 2002 2:31 pm    Post subject: Reply with quote
There was a couple of those dehumidifier crystal holder things in there.Used to fill up with water you know.Not no more though.
PostPosted: Sat Jul 20, 2002 5:39 am    Post subject: Reply with quote
Dehumidifier crystals are something different. If that's what's in your vent hose, there should be some water in there and some dissolved crystals. I don't know what D-con rat pellets look like, but I've seen dehumidifier crystals and they don't look like those pellets in your picture. I've also seen silica gel dessicant and they're little round semi-transparent dudes. I would still seriously consider the possibility that those could be rat pellets and get them checked out - at least get some D-con from wherever and do a side by side comparison. After you determine for sure what it is and if necessary, the authorities are done looking at it, clean and rinse out the vent hose real good.
Joes924
PostPosted: Sat Jul 20, 2002 8:20 am    Post subject: Reply with quote
I dont know what they are theve just been sitting in the garage in a can ...HHmm has this car been stored before..
larso
PostPosted: Tue Jul 23, 2002 9:26 pm    Post subject: Reply with quote
dwak
HAHAHAHAHAHAHAHA!
larso
PostPosted: Tue Jul 23, 2002 11:02 pm    Post subject: Reply with quote
This is black comedy! JOE GET IT CHECKED OUT. I'd be kinda worried.
Rick MacLaren
PostPosted: Wed Jul 24, 2002 12:49 am    Post subject: Reply with quote
Could it be a kind of silicon to rid the car of humidity?
