Nissebus
Joined: 07 Jun 2011 Posts: 20 Location: Gothenburg, Sweden
Posted: Sun Jul 07, 2013 3:24 am Post subject: Headlight relay on a -81 n/a. Where is it?! |
Hi, I'm wondering where the relay for the high/low beam on the left side is located. It isn't amongst the fuses as all the other relays.
The reason I'm asking is because the high beam on the left isn't working, while the right one does.
/Tim. _________________ 924 -81 "The Frogmobile"
”Before you criticize someone, try walking a mile in their shoes. That way, when you do criticize them, you’re a mile away AND YOU HAVE THEIR SHOES!” |
Posted: Sun Jul 07, 2013 4:49 am Post subject: |
There is no relay for the headlights on the later model cars. It was replaced with a jumper in the relay holder. If you can't find a blown fuse, it's possible you have a burned pin on the fuse block. Do a search and you should find a write up I did on the subject... _________________ erstwhile owner of just about every 924 variant ever made |
scm924s
Posted: Sun Jul 07, 2013 5:00 am Post subject: |
Each headlamp operation has a separate fuse, ie., dip and main, left and right, 4 fuses. _________________ 1984 n/a Ruby Red Metallic
1988 924S Guards red- sold
1986 924S Guards Red - sold
1984 n/a Black - sold
1980 n/a Le Mans#1 - sold
1980 n/a Le Mans#2- sold
1977 Martini - sold |
Nissebus
Posted: Wed Jul 17, 2013 8:04 pm Post subject: |
I figured out that the problem lies within the fuse block and It seems like the pin is broken inside. Is there a way to fix this or do I have to by a new fuse block?
(Thanks for the write up Ideola, it helped alot ) _________________ 924 -81 "The Frogmobile"
Nissebus
Posted: Sun Jul 21, 2013 8:06 pm Post subject: |
Nevermind. I opened the fusebox, soldered the broken pins back and taped the fusebox back together. Not the prettiest sight perhaps, but the headlights are now working.
Great sucess!  _________________ 924 -81 "The Frogmobile"
scm924s
Posted: Mon Jul 22, 2013 12:00 am Post subject: |
result ! _________________ 1984 n/a Ruby Red Metallic
