JayZzzz4
Joined: 23 Sep 2008 Posts: 544 Location: Milwaukee, WI USA
Posted: Mon Sep 19, 2011 11:59 am Post subject: 951 A-Arm |
Could someone please tell me the A & B dimension?
 _________________ White 1987 Porsche 924S manual |
Posted: Tue Sep 20, 2011 6:44 am Post subject: |
I measured 7.75 inches from the CL of the pivot arm to the CL of the sway bar hole. Draw a line from the center of the center of the pivot bracket(inboard) to the center of the ball joint and then measure the 7.75". If your trying to fit a late model sway to an early steel arm, I tried a 1.5" hole with a short piece of 16 ga exhaust pipe welded in, 1/8" plate washer on top (using Energy Suspension bushings)to get the height of the late model drop link close and came out too close to the strut housing to work well. I haven't checked out what the problem is and won't be able to figure it out for another couple of weeks as we are out of town. _________________ Mike
'67 MG Midget Dp
Khal
Joined: 26 Sep 2003 Posts: 4872 Location: Sunny and lovely interior BC, Canada
Posted: Tue Sep 20, 2011 8:05 am Post subject: |
Just throwing it out there, might be irrelevant in this case, but... all dimensions on these cars are metric. It would be very easy to inadvertently round out a millimetre or two depending on how many decimals of an inch you round to.
Might be unimportant for some applications but I'd imagine you'd want to be pretty accurate with suspension geometry measurements. _________________ '80 924 Turbo |
gohim
Posted: Wed Sep 21, 2011 8:09 am Post subject: |
There are two different alloy front control arms with different lengths.
Before you accept any dimensions, maybe you should specify which alloy lower control arms you want the dimensions from. |
Joined: 23 Jul 2007 Posts: 1081 Location: The Netherlands
Posted: Wed Sep 21, 2011 3:17 pm Post subject: |
length of the control arm (before/after 86) shouldn't matter, the sway bar mount in on the same position. _________________ 937 trackday car
JayZzzz4
Posted: Sat Sep 24, 2011 1:36 am Post subject: |
I knew about the two different sizes A-arms, but I always thought the holes for the sway bars would be the same since the bars are interchangeable for all 951’s and through the 968’s as well. I have M030 sway bars (26.8mm front) with the drop down links for the last two years and want to use it. I know a person who autocrosses an 88 924S who just shoved the bigger bar into the current 924 a-arm sway bar bushing. I did mount one side in place that way and would rather use the drop link method. There is too much friction for movement that way, which would hinder the function on the sway bar in the first place. My plan is to locate the hole, drill it, weld a thick washer (.125”?) on both sides and do a final weld around the whole a-arm since its made out of two plates. Any thoughts on that approach?
MikeJinCO, do you happen to know the “B” dimension? Thanks _________________ White 1987 Porsche 924S manual |
Andrew NZ
Posted: Sat Sep 24, 2011 7:02 am Post subject: |
| JayZzzz4 wrote: | | My plan is to locate the hole, drill it, weld a thick washer (.125”?) on both sides and do a final weld around the whole a-arm since its made out of two plates. Any thoughts on that approach? |
I pressume you mean on your steel arms? I drilled a hole through my steel arms for the original style 924 drop links, as the arms didn't have the tabs on them. No reinforcing of the hole, but I did seam weld the arms. They've done thousands of competition miles like this, so I think your plan should work fine. _________________ Andrew
1977 RX924 race car
12a bridgeport supercharged
www.race4-dcup.co.nz |
JayZzzz4
Posted: Sat Sep 24, 2011 8:52 am Post subject: |
Yes, -the steel A-arms. Good to know they hold up just fine. Thank you _________________ White 1987 Porsche 924S manual |
