Clutch talk
PostPosted: Tue Feb 22, 2011 11:24 am    Post subject: Clutch talk Reply with quote
Does anyone have the link saved with the 911 pressure plate that works for the 931?
I'm fixing to use a spec stage 2+ bronco II clutch disk and 911 pressure plate, resurfaced oem flywheel.. is that crazy?
PostPosted: Tue Feb 22, 2011 11:40 am    Post subject: Reply with quote
Here's one:
http://www.924board.org/viewtopic.php?t=27490&highlight=pressure+plate
PostPosted: Tue Feb 22, 2011 11:44 am    Post subject: Reply with quote
Score, thanks Dave.
Did you end up purchasing a 911 pp? The ebay link Dan posted is NLA. So the part number for the aluminum/iron version isn't available there.
PostPosted: Tue Feb 22, 2011 11:50 am    Post subject: Reply with quote
No I haven't, mine still works.
joe b
PostPosted: Wed Feb 23, 2011 9:45 am    Post subject: Reply with quote
Trying to sift through all of this information, but I am kind of a noob.
I'm looking for a clutch kit for my '80 931, which I'm VW flat tops in, as well as probably a boost controller. Just wondering what kit they recommend I buy. I am not sure how much extra power I'll be getting with these mods, or how much power the SACHS clutch kits are rated for.
I'd really appreciate some links to look at. I would prefer to keep it cheap if I can, but then again I don't want to find myself having to do another clutch job in the too-near future.
Any recommendations?
PostPosted: Wed Feb 23, 2011 10:24 pm    Post subject: Reply with quote
The hybrid alloy-iron version of the 915 pressure plate is 915.116.001.16
They are NLA new from Porsche, and I have been unsuccessful finding an aftermarket equivalent. The .27 all iron version is readily available and increases the clamping force, don't recall off hand by how much, but it seems like a reasonable upgrade for minimal cost on a modified '31.
Not sure the Stage II disc is really required, especially on a street car. The folks I discussed this with urged me to stay with the stock disc and just use the 915 pressure plate.
Just make sure you're absolutely certain which version of the flywheel you have before investing in clutch components. I've been hesitant to order from Spec because I'm not 100% certain they are aware of the variations...encountered this problem with Fidanza...so a call or two to Spec would be advisable before you spend $$$.
There are three versions of the flywheel I am aware of:
  1. Flywheel 931.102.205.05 M31.01/02, model years 1979-1980 : will fit (spring-damped) clutch plate 931.116.011.04 and pressure plate 931.116.001.02
  2. Flywheel 931.102.206.01 M31.03/50 81-onward : will fit (spring-centered) clutch plate 931.116.011.04 and pressure plate 915.116.001.27/16
  3. Flywheel 931.102.206.03 M31.04 81-onward : will fit (rubber-damped) clutch plate 944.116.012.04 and pressure plate 931.116.001.3
PostPosted: Thu Feb 24, 2011 7:55 pm    Post subject: Reply with quote
suppose it's all determined on what your trying to achieve...
206.01 flywheel with the 911SC all aluminium pressure plate and clutch will work, but you have to drill out the clutch rivots and replace the centre section (which is a 20mm diameter spline) and replace it with your old spring clutch spline centre.
Once you drill out the old rivots send an M4 or M5 tap down the hole for some bolts.
Note that the new clutch has double springs ( inner and outer )
PostPosted: Fri Feb 25, 2011 7:18 am    Post subject: Reply with quote
Well, I'm going to need a clutch disc that can take some punishment.
The last OEM clutch took plenty of punishment but after pulling it out, it was quite clear that it was slipping... a lot.
Autocross/HPDE/Drag Racing(gasp!) is in it's future.
I may even attempt to use my launch control this summer... I was to afraid to launch with it last summer...
joe b
PostPosted: Fri Feb 25, 2011 9:37 am    Post subject: Reply with quote
There's a company in California called South Bend Clutch, and while their website is crap, my friends around here say their clutches never slip. I called and one for the 931 would cost $750 apparently.
PostPosted: Thu Apr 28, 2011 3:07 pm    Post subject: Reply with quote
http://cgi.ebay.com/ebaymotors/SACHS-RACING-POWER-CLUTCH-KIT-Porsche-911-911S-911T-72-/330552851454?pt=Motors_Car_Truck_Parts_Accessories&hash=item4cf67c3bfe#ht_2155wt_725
No affiliation, this is the all aluminium pressure plate, as mentioned you need swap out the splined centre with your previous disc centre as it has 20 splines. This is fairly easy to do, I used the 206.01 flywheel in this setup.
Be able to give a good comparison when Scorpio gets his car on the road as he has a spec stage 2 IIRC. Stu
PostPosted: Thu Jul 14, 2011 12:28 pm    Post subject: Reply with quote
Stu, if I'm following you, the clutch disc that comes in the above-linked kit has the 25 spline center? So it should be direct bolt on for a 931? And you're using the late S2 .03 flywheel?
PostPosted: Fri Jul 15, 2011 10:53 am    Post subject: Reply with quote
OK think I messed up with my info, going to go and edit the old posts now too...
Also it took ages to find this, so save a copy....
http://clutchworld.net/pic/pdfcatalog-file1.pdf
From looking there is only one power clutch kit available
PC200-1 and comes with a 20T spline centre
which another board member and myself have veified you can change your old splined hub out for... drill out the old rivots and either use new heavy duty rivots or drill and tapp the lugs and fit with bolts, I went with an allen key head on mine (20mm length IIRC)
you also swap in the 4 new dual springs for the old hub springs and rplace You can't use the new throwout bearing either.
So what you get is a new clutch and an aluminium pressure plate that's 3lb lighter than stock and has double the clamping force.
As far as pressure plates, to make it clear the model that goes with the rubber centred clutch and pressure plate 206 .03 CANNOT be used
You have to USE the pressure plate that goes with a spring centred clutch. 206.01
to help identify the flywheel clutch combo -
with the rubber clutch the 206.03 flywheel pressure plate will have a positve offset, i.e around the lip which bolts to the flywheel the gripping face extends beyond the lip.
206.01 flywheel and spring centred clutch the pressure plate will have a negative offset of 5mm on the gripping face.
regards
PostPosted: Fri Jul 15, 2011 11:40 am    Post subject: Reply with quote
The 205.05 and 206.01 flywheels use the same pressure plate and spring-centered clutch disc, so the PC200-1 pressure plate should work with either arrangement. If you have a 1982 S2 with an M31.04 engine code, the PC200-1 won't work for it, as that is the engine that came with the 206.03 flywheel.
More to add but gotta run just now...
PostPosted: Fri Jul 15, 2011 1:01 pm    Post subject: Reply with quote
What I was going to add is that it would be interesting to find out if you could purchase ONLY the pressure plate from this kit, then source the OEM clutch disc and throw-out bearing separately.
PostPosted: Sat Jul 16, 2011 11:27 am    Post subject: Reply with quote
EBS have these from kennedy engineering,
http://www.ebsracing.com/item.wws?sku=901116001LWK-1&mfr=KEP
