pfgascoigne
Joined: 20 Nov 2010 Posts: 11 Location: Dibden Purlieu. Hampshire
Posted: Thu Dec 02, 2010 9:02 am Post subject: VW/Audi 1.8 Turbo Motor |
Does the VW/Audi 1.8 Turbo motor fit directly on to a 924 NA/Turbo bellhousing? And is the 2.0 Fsi engine just a bored out 1.8T which will also fit the same bellhousing? _________________ Porsche 924 Carrera GT (Fake!) |
gegge
Posted: Thu Dec 02, 2010 9:10 am Post subject: |
NO!
I thought so and bought the little 4-cyl but it doesnīt fit. It isnīt even close. Check my thread about VW engines that doesnīt fit.
What you can do is take the 02J gearbox and make an adpater. Google RWD Corrado and you will find the details. _________________ Carl Fredrik Torkildsen
pfgascoigne
Posted: Fri Dec 03, 2010 6:56 am Post subject: |
gegge,
You've bought a 16v 2.0l ACE engine I think, but I want to use the smaller 1.8T engine. Or are the bellhousing layouts the same on both engines?
You seem to be some way towards the solution looking at your thread. In the bottom picture, you have the torque tube bolted through the VW(?) bellhousing, and through what looks to be a big steel plate. This is also bolted to the bellhousing, I suppose as a load spreader. Can you not just weld an aluminium doubling plate to the bellhousing and bolt the end of the torque tub to that?
Or am I jumping the gun and this is version 1.0 (trial setup)! _________________ Porsche 924 Carrera GT (Fake!) |
gegge
Posted: Fri Dec 03, 2010 7:32 am Post subject: |
Iīm not 100% sure, but close. All 4-cyl has the same boltpattern. Well, maybe not the first 1.6l but the rest: PL, KR, ACE, 6A, 9A, ABA, ABF and so on plus all 1.8t. Iīm almost certain that 1.9tdi fits as well, the forged crank is an easy swap into the petrols and the block is thicker.
Modifiing a 924 bellhousing is too complicated compared to the FWD 020, 02J or 02A design. Easier to adapt the clutch too.
This is the thread I was refering to:
http://forums.vwvortex.com/showthread.php?2979430 _________________ Carl Fredrik Torkildsen
pfgascoigne
Posted: Wed Dec 08, 2010 8:24 am Post subject: |
gegge,
Do you know the origins of the bellhousing being modified in the pictures? _________________ Porsche 924 Carrera GT (Fake!) |
gegge
Posted: Wed Dec 08, 2010 9:30 am Post subject: |
Iīm afraid that I donīt. Guessing that you could taka a plain 02J and cut or grind the housing for the differential. _________________ Carl Fredrik Torkildsen
Rocco R16V
Posted: Fri Dec 17, 2010 3:45 pm Post subject: |
I looked into this and I'm pretty sure he used the bellhousing from a 02A
more pics
gegge
Posted: Fri Dec 17, 2010 5:18 pm Post subject: |
Interesting, what is the physical difference between the 02J and 02A except the rod/wires gearchange and size of the clutch? _________________ Carl Fredrik Torkildsen
Rocco R16V
Posted: Tue Dec 21, 2010 12:46 pm Post subject: |
| I dont know? probably could use either one. |
931 twinturbo
Posted: Fri Apr 15, 2011 3:35 am Post subject: |
Audi S2, S4, S6 engine fits the 924 2.0L Bellhousing.... Not many upgrades... A friend of me tryed it some years ago, but the car had to much rust  _________________ 911 Targa 1974 Turbolook/Outlaw
964 C2 1992mod
924 Carrera GTS Look(Project)
924Na stock 1982Mod
*911S Targa slantnose 1975mod
*924Na 1977Mod Carrera GT kit
*944NA Type 1 1984Mod
*924 Turbo Serie2 1980mod
*924 Turbo Serie2 1980Mod
*924NA 1982Mod |
the_mad_electrician
Joined: 16 Nov 2009 Posts: 1073 Location: Central Georgia
Posted: Tue Apr 19, 2011 7:26 am Post subject: |
| 931 twinturbo wrote: | Audi S2, S4, S6 engine fits the 924 2.0L Bellhousing.... Not many upgrades... A friend of me tryed it some years ago, but the car had to much rust  |
Are you talking 2.7 turbo or the 4.2 v8? _________________ 81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6 |
