gohim Guest
Posted: Sun Jun 16, 2002 2:09 am Post subject: |
The plastic caps come as part of a set with the injector seals. Generally, that is how you buy them, as part of a set.
The Porsche Dealer, or any of the aftermarket Porsche Parts Suppliers, or a Bosche Dealer should be able to sell you injector seal sets for your car.
The parts are packaged per injector. To replace the seals and caps on for injectors, you need to buy for sets (or sets of parts).
I have been told that some of the sets out there come with the wrong plastic caps. If it is the caps that you want/need, you need to verify that the kit/s will come with the correct parts before you order them. |
