dash16
Posted: Sat Jun 26, 2010 3:33 am Post subject: oil pressure |
it should always be at least above 2 on the gauge, correct?
and 5 on the the throttle?
what if after warming up, you're at like 1.5? and at like 4 on the throttle?
is this a sign on an issue? what could it be if you're not low on oil?
thanks _________________ 1987 Porsche 924S Black/Black. 5-spd.
Options: AFX C79 261 398 423 650 651 657
1987 Mercedes 190E 2.3-16 Cosworth Pearl Black/Black. 5-spd.
STUTTGART PREVAILS |
Rich H
Posted: Sat Jun 26, 2010 4:12 am Post subject: |
You should always have some on the gauge at al times, and more when you are on the move. While it's >1 hot idle then don't worry about it.
Rich _________________ 1994 Lotus Esprit S4 - Work in progress...
TJC
Joined: 04 Apr 2010 Posts: 828 Location: Northwestern-ish Arizona, USA
Posted: Sun Jun 27, 2010 1:05 am Post subject: |
I don't think you have a problem. The Porsche spec ( per Porsche publication WKD 423 320, 924S/944 Model Dimensions and Tolerances) is "approximately 4 bar at 5000 RPM @ 80 degrees C oil temperature".
For what it's worth, our '87 has about 1.5 bar at hot idle and 4 to 4.5 bar at speed. We use Mobil 1 and the ambient air temp here is in the 90's now.
An "old" rule of thumb is that hot oil pressure should be at least 10 psi for every 1000 RPM. _________________ '95 BMW 318i/5 ..."Pearl"
'04 BMW X3..."Xander"
Still on the Prowl!
www.ttrs1.com |
Posted: Sun Jun 27, 2010 3:37 am Post subject: |
| Electric guages can vary. Before I got excited I would screw a mechanical guage into the engine and check the pressure there. |
