Andrew NZ
Posted: Fri Mar 02, 2007 1:00 pm Post subject: Tie rod alternatives |
I'm in urgent need of a tie rod, but the local companies don't have a listing for them. Does any body know exactly what VW models will fit?
I have used "search" but couldn't find anything other than speculation. _________________ Andrew
1977 RX924 race car
12a bridgeport supercharged
www.race4-dcup.co.nz |
Posted: Fri Mar 02, 2007 2:26 pm Post subject: |
Go here - www.partsamerica.com and enter your year, make and model, then search on tie rod. Select a part, then if the option "See all vehicles this product fits" appears under "For Your Vehicle", click on it (many, but not all items include this option).
I did that, but could only find outer tie rod ends for the '77 924 and here are the other vehicles that use the same outer rod ends -
85-93 Cabriolet
80-84 Jetta
75-84 Rabbit
80-83 Rabbit Pickup
80-84 Rabbit convertible
75-88 Scirroco
80-91 Vanagon
In addition to those, the McQuay-Norris Tie Rod End lists these as other vehicles using the same ends -
75-78 Fiat 131
79-81 Fiat Brava _________________ "..it's made in Germany. You know the Germans always make good stuff."
Andrew NZ
Posted: Fri Mar 02, 2007 2:56 pm Post subject: |
Thanks Smoothie - that's a good starting point. _________________ Andrew
1977 RX924 race car
Min
Posted: Fri Mar 02, 2007 3:08 pm Post subject: Re: Tie rod alternatives |
| Andrew NZ wrote: | | I'm in urgent need of a tie rod, but the local companies don't have a listing for them. Does any body know exactly what VW models will fit? |
If you need an outer tie rod you can drill out the end and use a heim instead, as instructed in the bump steer modification listed in our tech section.
Andrew NZ
Posted: Fri Mar 02, 2007 6:27 pm Post subject: Re: Tie rod alternatives |
| Min wrote: | | Andrew NZ wrote: | | I'm in urgent need of a tie rod, but the local companies don't have a listing for them. Does any body know exactly what VW models will fit? |
Min |
Thanks Min, but its the inner joint that's worn. _________________ Andrew
1977 RX924 race car
Joined: 04 Dec 2002 Posts: 767 Location: Blyth, Northumberland, UK
Posted: Fri Mar 02, 2007 9:13 pm Post subject: |
the tie rod end is used on a few VW's, but looking at a parts place here for the actual tie rod it just lists as 924/944... _________________ Mars Red '78 Euro 924 n/a
http://www.cardomain.com/id/5150_uk
Graphite? Grey Metallic '85 (late model) 944 2.5
There are two kinds of pedestrians: the quick and the dead. |
Vince Ponz
Posted: Sat Mar 03, 2007 4:35 am Post subject: |
try Vertex in Florida. _________________ "Never let them see you sweat"
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock |
Allan
Joined: 08 Dec 2006 Posts: 22 Location: Estonia, Tartu
Posted: Tue Mar 06, 2007 2:43 am Post subject: |
I am behind the same problem and only alternative that I found was 944 inner rod and VW outer by Ruville products.
Description for 944 inner rod
General:
EAN 4011442588113
Status Normal
Quantity per Packing Unit 1
Packing Unit 1
Criteria:
Fitting Position Front Axle
Outer Thread [mm] M14x1,50
Thread Type with right-hand thread
Length [mm] 345
Description for 924 inner rod
General:
EAN 4011442584368
Status No longer available
Packing Unit 1
Criteria:
To Model Year 07/1985
Length [mm] 355
As You can see the 944 has 10mm shorter rod than 924, other parameters are the same. I havent used them but I think I will. I just have to measure on my car if I can use the 944 rod. _________________ Porsche 924-79-2,2L |
john h
Posted: Wed Mar 07, 2007 10:13 am Post subject: Re: Tie rod alternatives |
| Andrew NZ wrote: | I'm in urgent need of a tie rod, but the local companies don't have a listing for them. Does any body know exactly what VW models will fit?
I have used "search" but couldn't find anything other than speculation. |
I had the same problem on the GT so I ended up installing a couple of tie rods of a 944. Early 944 ones are the same as 924 but are no longer available from the local agents so you have to go for the later 944 units - and they're not cheap. Paul at Autobahn should have some good second hand ones if you're stuck. _________________ Remember a Porsche is not just for Christmas,
Andrew NZ
Posted: Wed Mar 07, 2007 2:11 pm Post subject: Re: Tie rod alternatives |
| john h wrote: | | Andrew NZ wrote: | I'm in urgent need of a tie rod, but the local companies don't have a listing for them. Does any body know exactly what VW models will fit?
I had the same problem on the GT so I ended up installing a couple of tie rods of a 944. Early 944 ones are the same as 924 but are no longer available from the local agents so you have to go for the later 944 units - and they're not cheap. Paul at Autobahn should have some good second hand ones if you're stuck. |
Thanks, I might have to give Paul a call. _________________ Andrew
1977 RX924 race car
PieszczoH
Joined: 03 Dec 2009 Posts: 66 Location: Warsaw Poland
Posted: Mon Mar 29, 2010 1:17 am Post subject: |
Hi there, as far as I understand John H managed to mount new type 944 manual steering tie rods to the 924 rack, am I right ?
also Lemforder catalogue states that 12093 position is for 924 2,0; 924S 2,5 and 944... and org. pn is: 944 347 033 01.
as far as I know some ppl here managed to mount to 924 rack some tie rods from VW GOLF/Rabbit mk2 which are 367mm long with 14mmx1,5 mm outer thread so VW Rabbit mk1 tie rods ends, or 944 power steering tierod ends work.
Does any one know what the the tie rod inner thread in manual steering 944/924S, its 22mmx??? |
