cvriv.charles
Posted: Mon Feb 08, 2010 6:50 pm Post subject: 951 inside a 924S chassis. |
Hello. I am new here. I post mostly over at pelican because of the fact that I own an 1986 951.
Unfortunately,... I wrecked my car. I am in need of a new chassis. Several guys from pelican suggested I get a 924S chassis and install all my 951 components to this chassis. From what I read this chassis is a lot lighter.
I also read that a german mechanic has already done this and it turned out to be one kick arse car. I was thinking that maybe I would take this route.
I have so many concerns though. I want to know how much modification is needed to pull off such a thing. I think I read that the engine harness for the 924S is on one side and the 951 harness is on the other side of the vehicle. That I would need to swap sides. I dont know whats involved with that. I was told that I need a turbo nose to fit the intercooler. What else?
I read that the 924S weighs about 2600 with a full tank of gas and a driver inside? The dimensions of the 924S is the same as the 944/ 951's right?
I saw a guy give away his 924S shell for free right on this very board. To bad im to late for that. Does anyone have a 924S chassis for a decent price? Im really in no hurry. Im actually trying to decide if I want to buy a chassis now(next month or so) or if I should put it off for awhile and just keep my eyes open for a 924S chassis and just see what happens.
For reason of simplicity,...I would love to just buy a 951 chassis and just move everything over. But this whole light weight super porsche thing has seriously caught my attention. My 951 has a K-28 turbo with #65 delcos and a guru chip. The engine puts out just about 300hp. I plan on rebuilding and modifying some so that I can be assure that my engine is putting out over 300hp. I also have a manual tranny with LSD and an oil cooler. Im figuring that if I could pull this off plus with some new body work and suspension upgrades etc,... I would end up with some kind of super car.
The big thing right now is how much work is involved and where and when to get a chassis?!?!?
Thanks guys. _________________ WTB: 924S chassis |
Posted: Wed Feb 24, 2010 2:07 am Post subject: |
Oops, noticed this post a while back and never responded.
When I was pondering this process, I came up with a couple guidelines. First, I really wanted the two cards side-by-side for the procedure, so both could be studied and the wiring hardnesses could be moved over in a methodical manner. Second, in order to use the factory IC, you would need to cut the radiator subframe from the 951 and weld it into the 924S. Finally, you'd need to be very patient about moving over all the heat shielding from the 951. You can also use the plastic tank from the 951 and improved tranny crossmember.
This is a very doable project and would result in a MONSTER car. I'd encourage you to try it, and people here or at Pelican would be ready to assist.
Good luck,
rasta _________________ Toofah King Bad
cvriv.charles
Posted: Wed Feb 24, 2010 4:24 am Post subject: |
I might give it a go. But I cant at the moment because im stupid busy with working on the house. That and im trying to start up a business too. So much on my hands right now. Thanks. _________________ WTB: 924S chassis |
Khal
Joined: 26 Sep 2003 Posts: 4869 Location: Sunny and lovely interior BC, Canada
Posted: Wed Feb 24, 2010 7:25 am Post subject: |
Rasta Monsta wrote: | This is a very doable project and would result in a MONSTER car. |
Not only can it be done, it has been done. The result is astounding _________________ '80 924 Turbo |
