Joined: 23 Jul 2007 Posts: 1081 Location: The Netherlands
Posted: Sun Dec 06, 2009 3:00 am Post subject: difference 931 S1 and S2 cylinderhead ? |
Is there any difference between the S1 and S2 931 cylinderhead ? So are they interchangeable ? _________________ 937 trackday car
Posted: Sun Dec 06, 2009 5:14 am Post subject: |
Was never in a situation to compare the two, but one minor item comes to mind. The later one might have the hole drilled for the turbo oiler breather, while the earlier one may not..? Easy to fix either way - either drill the hole/s, or install a block-off plate..
Other than that, I'm real sure they're the same and interchangable. _________________ "..it's made in Germany. You know the Germans always make good stuff."
Posted: Sun Dec 06, 2009 5:41 am Post subject: |
Here's the shot of the Series I Euro head I have. Note the right side where there are two threaded holes. Not a block-off plate either.
 _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
Posted: Sun Dec 06, 2009 5:46 am Post subject: |
But then, on Spike, also a 1980, you can see there is the turbo breather.
Posted: Sun Dec 06, 2009 7:35 am Post subject: |
Many S1 heads were either already built with the breather update or may have been taken back to the dealer and fixed later. I have only seen one S1 931 head aside from Dave's photo above that did NOT have the breather update port drilled. Aside from that, I am not aware of any other differences between the S1 & S2 head. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Sun Dec 06, 2009 9:16 am Post subject: |
I have the "uppgraded" pipe to on my s1 motor (sits on the shellf at the moment in favour of a s2 engine). It also has the uppgraded manifold. Could it be that the late 1980s models got the uppgrades from factory? _________________ 1980 924 Turbo
Posted: Sun Dec 06, 2009 10:18 am Post subject: |
| Cédric wrote: | | I have the "uppgraded" pipe to on my s1 motor (sits on the shellf at the moment in favour of a s2 engine). It also has the uppgraded manifold. Could it be that the late 1980s models got the uppgrades from factory? |
I think so. My two S1s are both in the 1400+ serial number range, and they both came with the update. _________________ erstwhile owner of just about every 924 variant ever made |
Rich H
Posted: Sun Dec 06, 2009 10:52 am Post subject: |
I'm sure I saw a leaflet issued to dealers to add the breather mod that included drilling the head _________________ 1994 Lotus Esprit S4 - Work in progress...
Posted: Sun Dec 06, 2009 11:00 am Post subject: |
More on the turbo breather updates here - http://www.924board.org/viewtopic.php?t=10536 _________________ "..it's made in Germany. You know the Germans always make good stuff."
jessy1984
Posted: Sun Dec 06, 2009 9:28 pm Post subject: |
they are both the same
just looked in pet same part number
only like mentiond here there's a modification for the turbo breather
if its not there just drill a hole in it  |
McGyver
Joined: 24 Feb 2009 Posts: 354 Location: Jelenia Gora - Poland
Posted: Tue Dec 08, 2009 7:05 am Post subject: |
I don't have this breather update too in my 931' 79 cylinder head. But I have plan to drill that hole and use it later in my engine rebuild project.
Cylinder head part number is: 931 104 301 3R
It's taken from 924 Turbo series 1 - 1979
 _________________ 931 82' - 5000km after full engine rebuild
www.mauser98k.internetdsl.pl - if someone like german rifles (English version avalible) |
moone924
Joined: 05 Feb 2003 Posts: 868 Location: Douglas Wyoming
Posted: Fri Dec 18, 2009 3:17 pm Post subject: |
I guess my late '82 931 has a early head on it, as it looks like the euro series one head Grenadiers has, with no breather. _________________ Ryan Moone
New philosophy : one car project at a time. |
Posted: Sat Dec 19, 2009 10:40 am Post subject: |
Spike has a series 1 US head. _________________ White 87 924S "Ghost"
Posted: Sat Dec 19, 2009 6:06 pm Post subject: |
thanks for the replies, I just bought a s2 head. It does have the hole in it.
My other s2 had didn't have the hol in it. But I drilled it in myself and made the modification pipe. _________________ 937 trackday car
pelican13
Joined: 21 Sep 2009 Posts: 22 Location: Provence ,FRANCE
Posted: Mon Dec 21, 2009 2:19 am Post subject: |
| I have an euro 931 of 1982 , CN100539 , there is no breather hole in the cyinderhead. |
