timing belt tensioner bearing
pcelenta
PostPosted: Fri Dec 18, 2009 1:29 am    Post subject: timing belt tensioner bearing Reply with quote
I bought a new tensioner/bearing for the timing belt from Performance products. does anyone know if I can reuse the old bolt and nut? a mechanic friend told me that I would have to get a different one. thanks, Paul
PostPosted: Fri Dec 18, 2009 5:28 am    Post subject: Reply with quote
I've always reused mine with no issues.
pcelenta
PostPosted: Fri Dec 18, 2009 5:39 am    Post subject: Reply with quote
Dan,
even with the new style tensioner bearing? bolt won't be too long?
regards,
PostPosted: Fri Dec 18, 2009 5:59 am    Post subject: Reply with quote
Hrrm. Not sure what you had on your car before. I only know of two types: my NA had one type, and all four of my 931 motors had the other, although looking at PET, it does appear to be a part split between the 79 and 80 model years, rather than being model specific. IIRC, the bolts are in fact different sizes, but I don't know which is which. And unfortunately, I don't see the bolt itself listed in PET. Wish I could be more helpful!
Min
PostPosted: Fri Dec 18, 2009 6:30 am    Post subject: Reply with quote
You may need to change the bolt. I did when I changed tensioner styles on my 924 NA.
Min
PostPosted: Sun Dec 20, 2009 1:55 am    Post subject: Reply with quote
Yes, if you're changing from the original style tensioner that was adjusted with a large wrench via the hex-shaped piece on front - to the new thinner cross-sectioned tensioner with the 2 small holes that take an adjuster tool.. Then yes, the old bolt should be too long. Correct fastening for the new one is a stud and nut. (Though a shorter bolt should do, the stud-nut are easier to work with.)
Remember to tension by turning the assembly counter-clockwise rather than clockwise.
