9XX Girl!
Joined: 20 Sep 2009 Posts: 1617 Location: Cornish Riviera SW England
Posted: Fri Oct 02, 2009 6:52 am Post subject: |
Got some gauges on there way to me. We will see when they arrive! I havent seen the PCB close up, it may be a multi layer board, in which case you wont trace them! The econogauge itself will just be a moving coil meter. once i know what kind of voltage gives full scale deflection, i could then look at designing my own circuitry _________________ 924 (84) N/A 2 ltr - 5 Speed - BLACK - Project (looking for 200BHP, any ideas!)
BOTH ON THE ROAD, BOTH USED EVERY-OTHER DAY |
Jakkq
Joined: 29 Sep 2008 Posts: 809 Location: Norfolk, Nebraska
9XX Girl!
Posted: Fri Oct 02, 2009 7:59 am Post subject: |
Thank you kindly hon but I like the retro 80s look of the stock yellow on black 944 gauges plus,.. got better things to spend £65 ($100) on.
I want to pass my bike test and build me a low rider! (before I get too old!) _________________ 924 (84) N/A 2 ltr - 5 Speed - BLACK - Project (looking for 200BHP, any ideas!)
9XX Girl!
Posted: Wed Oct 07, 2009 8:58 pm Post subject: |
Does anyone know how to open the tack without damaging it?
lucky with the millage on these new clock hay?
this is the one in my car at the mo
Posted: Wed Oct 07, 2009 10:44 pm Post subject: |
9XX Girl! wrote: |
Yeah, you have to work your way around the metal band bending it open on the back till you can pull it off. A small screwdriver or a very thick knife blade works. To re-assemble you simply squeeze the metal back down. |
9XX Girl!
Posted: Wed Oct 07, 2009 10:51 pm Post subject: |
hmm.... taught as much. was hoping for an easer option but will give it a go when I'm feeling patent and methodical. no good me trying unless I'm in the zone. _________________ 924 (84) N/A 2 ltr - 5 Speed - BLACK - Project (looking for 200BHP, any ideas!)
Posted: Wed Oct 07, 2009 10:58 pm Post subject: |
Yeah, it's kind of a PITA. Be careful that you don't cut yourself on the sharp metal edges. _________________ erstwhile owner of just about every 924 variant ever made |
Rich H
Posted: Wed Oct 07, 2009 11:00 pm Post subject: |
It's hard work and be careful it's easy to slip. Also beware of damaging the front face of the bezel it's easy to bend when finally prising it off.
I found a small electrical screwdriver was best but a bigger one was quicker! Once the bezel is off straighten the prised out lip with pilers so it goes back together easier.
Bending it back over - I just pinched it in a few places so that next time was easier to get into.
Rich _________________ 1994 Lotus Esprit S4 - Work in progress...
9XX Girl!
Posted: Wed Oct 07, 2009 11:09 pm Post subject: |
Thanx guys! will give it a go when i come home from work this eve.
I got a first aid kit so i'll be OK! if you don't here from me by tomorrow it means I've bled to death. _________________ 924 (84) N/A 2 ltr - 5 Speed - BLACK - Project (looking for 200BHP, any ideas!)
Rich H
Posted: Thu Oct 08, 2009 12:28 am Post subject: |
Don't forget to take pics! _________________ 1994 Lotus Esprit S4 - Work in progress...
Jakkq
Shurick
Joined: 15 May 2005 Posts: 524 Location: Russia, Moscow.
Posted: Thu Oct 08, 2009 5:57 am Post subject: |
I haven't been sitting in my 924 for a while but... I can't remember any problems with temp gauge readings. I'm above 6 ft tall so my line of site is rather high. And no problems. What I've been doing wrong? _________________ WBR, Shurick
'86 924S -- R.I.P.
https://www.instagram.com/ru_pacecar/ |
9XX Girl!
Posted: Thu Oct 08, 2009 11:02 am Post subject: |
Shurick which side is your steering wheel? Mine is on the right side. _________________ 924 (84) N/A 2 ltr - 5 Speed - BLACK - Project (looking for 200BHP, any ideas!)
9XX Girl!
Posted: Thu Oct 08, 2009 12:19 pm Post subject: |
OK then.
this is a poor quality photo of the tach being opened.
This is the back of it once open.
The moving coil part of the econogauge has two wires, Green and White connected to it.
I have removed the one at the top (white) and left the one at the bottom (Green) still connected.
I have clipped a test lead to the bottom terminal.
This is the front without any voltage applied
On this pic below, i have used the other end of test lead and a slightly
flat 1.5volt AA battery (1.2v) to apply power to the top terminal.
This gives Full Scale Deflection (FSD). The needle doesn't go hard
over but does strike the full scale stop, therefore i am gona flatten (discharge)
the battery by 0.5v increments until it gently makes the stop.
This should give me correct FSD Volts,
Once i have the FSD Volts and the pinout data for a vacuum MAP sensor,
i can calculate the correct resistor values for a potential divider circuit (with trim pot for calibration),
to convert the 5volts at 0.1mmHg of vacuum to FSD Volts that will power the moving coil meter,
thus creating an electrical vacuum gauge A.K.A econometer
Shurick
Posted: Thu Oct 08, 2009 4:32 pm Post subject: |
9XX Girl! wrote: | Shurick which side is your steering wheel? Mine is on the right side. |
Sorry, missed that. _________________ WBR, Shurick
'86 924S -- R.I.P.
