JackRabbit
Joined: 11 Aug 2008 Posts: 147 Location: Clarion, Pennsylvania
Posted: Wed Aug 05, 2009 3:15 pm Post subject: Rattling Exhaust |
so my slight exhaust rattle has matured into a full on cacophonous symphony that is ever so annoying and I'm wondering what the best method is for dampening, adjusting, realigning... etc? _________________ '79 Porsche 924
'05 Honda Civic
'07 BMW K1200R
'78 Honda Express
'52 Willy's
'58 Wheel Horse |
masterdave
Posted: Wed Aug 05, 2009 3:48 pm Post subject: |
| sounds like you have an old rusted system, unless you have a welding torch and what not, it is best to just take it to a muffler place and have them replace it, they are one of those things that just goes and cant be fixed just has to be replaced. |
wombat
Joined: 07 Jun 2008 Posts: 422 Location: Melbourne, Australia
Posted: Wed Aug 05, 2009 4:24 pm Post subject: |
check the rubber hangers before going off to get a new exhust. But maybe you will some welding and what not????? _________________ 1977 924 2.0 Auto |
emoore924
Posted: Wed Aug 05, 2009 11:39 pm Post subject: |
| Catalyic converter shield coming loose? They make a racket when the mounts start to rust away... |
JackRabbit
Posted: Thu Aug 06, 2009 5:14 pm Post subject: |
well I should add that I recently removed the whole exhaust before replacing my shift linkage bushings... it was rattling before that but only slightly... and the catalytic converter shield was pretty bad so I just removed it... there is, however some kind of a heat shield above that muffler that's pretty rusty and loose... but that isn't the soul source of the sound...
so did I not reinstall in properly or should I be looking to replace this thing and if so, what would you estimate I'm looking at? _________________ '79 Porsche 924
'05 Honda Civic
'07 BMW K1200R
'78 Honda Express
'52 Willy's
'58 Wheel Horse |
masterdave
Posted: Fri Aug 07, 2009 4:01 pm Post subject: |
| if im looking at the right thing on dcauto.com it looks like it will cost around 70$ for the new heat shield and, if you replace it in and around 100 for the new tail pipe. you may also need mounts which should be in the 40$ range. bad mounts have been on my list of things to repair for a long time, some of them look like pieces one can get from home depot or your local hard ware store. |
