Posted: Fri Jul 24, 2009 1:02 am Post subject: Bending Fuel Line |
So, I am needing to reroute some fuel lines on my plastic tank project, and I am wondering if anyone has had luck bending the factory lines. I ask because they are awfully thin.
TIA
rasta _________________ Toofah King Bad
Posted: Fri Jul 24, 2009 1:10 am Post subject: |
Are they any different than brake line? Haven't tried it myself, but I would assume that standard brake line bending tools would work just as well. You may need to get one of the special tight radius ones depending on what you need to do? _________________ erstwhile owner of just about every 924 variant ever made |
DOCO
Joined: 04 Aug 2006 Posts: 1111 Location: Keswick Ontario Canada
Posted: Fri Jul 24, 2009 1:37 am Post subject: |
try this wrap a slightly oilly shoprag aound the line where ya want to bend it.the trick is get the rag realy tight on the line...and just bend it with your hands should have a nice bend with no kinks!!!Old indian trick been useing it for years in my feild.haven had one kink yet!!grt that rag tight though _________________ Doco "where am i going and why am i in this handbasket"author unknown
79 924 N/A "Webster"
_______
/______\
[+]___[+]
\0 924 0/
[__]..[__]
"WEBB STR" |
Slam
Posted: Fri Jul 24, 2009 5:10 am Post subject: |
^+1
Also a good way to make money in bars. "I'll bet you I can bend a cigarette in half without breaking it!" _________________ '84 944 - kid blew motor
'80 924 - gone
'78 924 - gone
Posted: Fri Jul 24, 2009 5:22 am Post subject: |
Get the rag tight how? Like a tourniquet?
And to answer your question, Dan, the fuel return line is larger, and seems much thinner-walled than a brake line. That's why I was worried about it and wanted to know if it had been done on our particular metal lines. _________________ Toofah King Bad
DOCO
Posted: Fri Jul 24, 2009 5:24 am Post subject: |
wrap it around completely from one end to rag to other end.like you would rolla....cigaret _________________ Doco "where am i going and why am i in this handbasket"author unknown
_______
/______\
[+]___[+]
\0 924 0/
[__]..[__]
"WEBB STR" |
Posted: Fri Jul 24, 2009 5:52 am Post subject: |
| DOCO wrote: | | like you would rolla....cigaret |
and here I wuz thinkin' Rasta was the masta of such matters _________________ erstwhile owner of just about every 924 variant ever made |
DOCO
Posted: Fri Jul 24, 2009 6:07 am Post subject: |
you would think!!! oh and when you roll it twist it tight around the line!!not what you guys are thinkin  _________________ Doco "where am i going and why am i in this handbasket"author unknown
_______
/______\
[+]___[+]
\0 924 0/
[__]..[__]
"WEBB STR" |
