owenexile
Joined: 05 Jun 2009 Posts: 333 Location: Australia , Bunbury
Posted: Sat Aug 15, 2009 1:32 am Post subject: Headlights problem? |
Hi there
Well since i bought the car (924 N/A 1982) the lights wasnt really bright . So i read about it and it ogirinally came out with a sealed beams. So the PO did the semi-sealed beam swap with aritic blue lights 45/60 . So the problems begin.
1st was the headlights will go off randomly and come back again few seconds later(while this was happinging i coulve switch to brights/longlights and it worked) So i redid the all the wires at the battery + and - . So then the lights was fine but recently my left side decided to not work anymore(brights/longlights still works) So i thought it coulve beem the light but its not because if i swap lights the right side still works fine. So i tought it can be a earth problem and i checked my earth connection and its not that.
Heres the coulours
Yellow -
Brown - earth
White - i think its the brights/longlights
While i was checking this cables my power reading is about 11V ( Car is stading since im fixing alot of thigns and waiting for my tapids to arrive. ps. i have tinkerd with the lights abit before testing the cable voltage output)
Its kinda hard to trace i think the problem is the yellow cable , i thought il just trace the wires where both sides come toghter then just connect the right yellow cable with the left side's cable , i have no idea if it will work so thats why im here.
Any1 had this problem before?
Lastly my lights isnt really bright and the lights in it cost A$40 per light because apperently it got 20m longer light then any other light , but in my case the lights only light about 20m....
Thanks |
poorsha924
Joined: 13 Nov 2007 Posts: 143 Location: Kansas City Mo
Posted: Mon Aug 17, 2009 9:48 pm Post subject: headlamp woes |
Hi there
Your problem could be caused by a couple on things. first 11 volts is on the low side to make the lights work. especcially with HIL. I would rechage my battery get it up to 12.5 volts the wiring on your 924 was not made for higher wattage bulb. puts a heavy load on the wiring ,switch & the fuse box. make yourself a load tester this is the only way to confirm you have enough current flowing across the wiring. test lights & volt meters will not tell you about current flow get a brake light socket attach a couple of wires to the the socket& put a bulb in it. There you go. now you can test your circuits. If the bulb does not light up dim or not at all you have a wiring concern. I would also add extra ground cables to the car make the starter crank faster wipers work much better & better charging system. the achilles heel of 924,s is the ground side of the system Got to have good grounds Hope this helps let me know if U need more FYI
Poorsha 924 _________________ 79 924S snailshell
audi big bore t-body
16" turbo wheels |
Posted: Tue Aug 18, 2009 5:06 am Post subject: |
Just to tie this loose pup to it's fraternal twin - http://www.924board.org/viewtopic.php?t=30038 _________________ "..it's made in Germany. You know the Germans always make good stuff."
