924 EFI Conversion
Insane
PostPosted: Sat Jun 20, 2009 4:12 pm    Post subject: 924 EFI Conversion Reply with quote
HI everyone,
I'm new here. Six month ago I've bought a Porsche 924 and I've started thinking over some tuning for it. So the first step was the EFI conversion.
Now it's finished.
I've seen some posts here about that and I'd like to share my experience here for a case someone would like to do something similar.
Actually, I haven't seen it mounted on the car yet, but it runs well on a dyno.
For the conversion you'll need:
- ECU and wiring harnesses
- Oxygen sensor //placed on the downpipe
- Air mass meter
- Water temp sensor //placed in the cylinder head instead of thermo-timer
- crankshaft positioning sensor and a crankshaft gear
- throttle positioning sensor // placed on the throttle body
- knock sensor //best place I've found is near the intake manifold
- fuel rail + fuel pressure regulator (I've heard that Ford Sierra '99 is suitable)
- injectors
- idle valve // placed on the place of cold start valve in the intake manifold
<UPD>
- new starter, fan, fuel pump relays
- destributorless ignition module, hall effect sensor (or a new Tacho gauge)
</UPD>
You will also need to machine some stuff:
- injector's fitting adapters
- fuel rail & bracket
- water temp sensor adapter
- crankshaft pos. sensor bracket
- crankshaft gear should be centered on the crank
- throttle positioning sensor bracket adapter
- some piping for AFM may be required
For proper set-up you'll need:
- wide-band Oxygen sensor and logger
- ECU flasher and the software (online programmable ECU is the best)
- a Dyno for the best tuning
- may be something else...
What do you get?
- no hot start problem as well as no cold start problem
- a bit more horsepower
- quicker throttle response
- fully adjustable system almost ready to accept turbo
My case is a custom EFI conversion kit built on J5.1 ECU which is used in most new russian cars and is an analogue of BOSCH ECU
so you may ask qeustions if you're doing the same - I'll try to help you
UPD:
I've just took it back from the workshop and made about 400km back home.
1) J5 EFI & Ignition installed
2) GETRAG Dogleg gearbox installed (Damn, it's fun!)
3) All wiring changed an rebuilt. it's almost as stock now!
Best regards,
Vladimir Linkevich
CorsePerVita
PostPosted: Sat Jun 20, 2009 4:22 pm    Post subject: Reply with quote
Great information, may wanna fix your image links though. They need a link to the image file itself. such as www.whatever.com/something/something.jpg
Great info though thank you for sharing, i'm looking into EFI conversion actually for my 77' so i'm digging like mad for info.
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS
Insane
PostPosted: Sat Jun 20, 2009 4:52 pm    Post subject: Reply with quote
I'll repost images on an other hosting now and fix.
That's a huge amount of work! I've ordered the kit, so I was waiting for two month for the development and production of the first sample.
It cost me 1.4k aprox, and I do not regret that I didn't start doing it myself.
I will take my car back tomorrow after a week of mounting new engine, gearbox an some electric work. So I will write my feelings tomorrow and I will probably have some more photos and diagrams.
Insane
PostPosted: Sat Jun 20, 2009 5:04 pm    Post subject: new plans Reply with quote
I've got more plans
- Brakes stage 1 upgrade (bought it already) // use 944<85 brakes, hubs and knuckles
- Installing a turbo on 2.0 NA
- Brakes upgrade stage 2 // Porsche 996 calipers and rotors (this requires some more changes)
- 17/18 inch wheels
- Porsche 944 fenders (or widebody)
- rebuild NA to Turbo // 300 flywheel hp est.
something else, I think
PostPosted: Sat Jun 20, 2009 5:21 pm    Post subject: Reply with quote
Very nice work...
Throwing on a turbo will make it easy to get 300hp....only problem is the rest of a NA cant take 300hp....
You will also need to sort out...clutch.....stronger gearbox...torquetube...perhaps pistons and engine internals
1979 NA
my Porsches Arse!!!
Insane
PostPosted: Sat Jun 20, 2009 5:33 pm    Post subject: Reply with quote
Scorpio wrote:
Very nice work...
yeah for 300HP - right - starting from a comlete engine rebuild, changing cylinder head channels, valves etc + new pistons and rods. and so up to the wheels
I'm planning NA for 200 HP with turbo. I hope Porsche has enough strength to handle that.
PostPosted: Sat Jun 20, 2009 5:36 pm    Post subject: Reply with quote
Insane wrote:
Scorpio wrote:
Very nice work...
yep..200 is more like it....according to Raceboy who has pushed the limits of the NA we start seeing clutch failing just before 200hp and 1st and 2nd gears around 210 up
1979 NA
my Porsches Arse!!!
PostPosted: Sat Jun 20, 2009 5:41 pm    Post subject: Reply with quote
Nice work. I'm seeing some potential hood clearance issues here...
Rich H
PostPosted: Sat Jun 20, 2009 5:51 pm    Post subject: Reply with quote
Drop the hood a couple of times, clearances sort themselves out!
I have an EFI'd N/A there aren't many like us! What did it make on the dyno?
I have very similar plans - already got the brakes and the turbo plan is still lurking in the back of my mind...
200bhp is more than possible apparently - the racing cars produced plenty more than that and there are high power turbo's on standard internals.
Insane
PostPosted: Sat Jun 20, 2009 8:13 pm    Post subject: Reply with quote
I have no dyno diagrams yet cause my car is in the workshop still. But they say it's about 130+hp on 98 petrol. Like a new stock.
I've decided to change all wiring as well so this will make a delay for couple of days.
Insane
PostPosted: Sat Jun 20, 2009 8:20 pm    Post subject: Reply with quote
This is a dyno, so the air piping is not the same as on the car.
Shurick
PostPosted: Sun Jun 21, 2009 8:16 pm    Post subject: Reply with quote
Great setup! But why do you use MAF? J5.1 can run with MAP and it's gives much more reliable system.
WBR, Shurick
'86 924S -- R.I.P.
https://www.instagram.com/ru_pacecar/
Insane
PostPosted: Sun Jun 21, 2009 8:43 pm    Post subject: Reply with quote
the system was first designed as an easy easy setup kit, so drilling the intake manifold to fit MAP seemed to be more problematic.
I think i'm going to have an upgrade for MAP soon when fitting a turbo on it.
Insane
PostPosted: Tue Jun 23, 2009 5:44 am    Post subject: tacho Reply with quote
Hey, guys!
Can anyone help me?
TACHO question.
I'm using two coil distributorless ignition, so I cannot connect the stock tacho to it.
I have a digital output on the ECU, but the tacho will not work with it as well.
So at the moment the distributor is still in place just for tacho signal.
Any Ideas on connecting the tacho gauge?
Shurick
PostPosted: Tue Jun 23, 2009 6:57 am    Post subject: Reply with quote
You need a converter to force it to work. Unfortunately, I can ask my friend to make it clear only at friday: I'm out of Moscow now.
WBR, Shurick
'86 924S -- R.I.P.
