Grinding
Jakkq
PostPosted: Sun Jun 07, 2009 6:20 pm    Post subject: Grinding Reply with quote
So this has been going on for quite some time now. I own a 79' 924 N/A. The problem is that when I shift into second gear, it will sometimes make a short grind, but still go into the gear. I've never had it grind in 3rd, 4th, or 5th, but 2 seems to hate me. Once in a blue moon, when I shift down into 1st it does this as well.
1979 Porsche 924- Snailshell
http://porsche924workblog.blogspot.com/
CorsePerVita
PostPosted: Sun Jun 07, 2009 6:40 pm    Post subject: Reply with quote
Hmm.. Shift linkage issues... worn bushings... tranny flush... bad synchros... clutch... ?
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS
D Hook
PostPosted: Sun Jun 07, 2009 11:32 pm    Post subject: Reply with quote
Snail shell tranny, right? Famous for bad 2nd gear synchro. Try a search on the board for more info. You're not alone.
'80 924 n/a SOLD
Jakkq
PostPosted: Mon Jun 08, 2009 8:14 am    Post subject: Reply with quote
http://img20.imageshack.us/i/file0054a.jpg/
Can you tell from this picture if this is a snailshell?
2Fast
PostPosted: Mon Jun 08, 2009 8:18 am    Post subject: Reply with quote
If you have an 1979 924 with a 5 speed, you most likely have a Snailshell tranny. You either have bad synchros, or, bad bushings. After awhile (if the synchros go ignored) they will wear out the tranny to a point where it cannot be fixed.
=====>Alex<=====
1979 Porsche 924 NA 5spd
1979 Parts Porshce 924 NA 5spd
CorsePerVita
PostPosted: Mon Jun 08, 2009 8:21 am    Post subject: Reply with quote
your transmission is in the back under your car. if you crawl under the car and snag a pic of the transmission we'll know for sure whether it's a snailshell or otherwise.
- 1999 Ducati 900SS
turboporsche924
PostPosted: Mon Jun 08, 2009 8:48 am    Post subject: Reply with quote
If first gear is down and second up its a snail.
1980 924 turbo
Jakkq
PostPosted: Mon Jun 08, 2009 8:50 am    Post subject: Reply with quote
PostPosted: Mon Jun 08, 2009 9:32 am    Post subject: Reply with quote
It is what it should be, and that is a snailshell (aka- "Getrag").
Here's the sticky topic on their shifting problems - http://www.924board.org/viewtopic.php?t=22871
Here's what an Audi gearbox looks like (from the rear-left looking forward) -
<click for larger>
Jakkq
PostPosted: Mon Jun 08, 2009 12:17 pm    Post subject: Reply with quote
So what would be the best way to get to the bushings to check them? I can't just lift up the shifter boot.
!tom
PostPosted: Mon Jun 08, 2009 2:49 pm    Post subject: Reply with quote
It's all covered in the thread Smoothie indicated above.
All of your questions will be answered here.
Basically, the best way to do it involves dropping the transmission to replace the joints on the shift linkage where it meets the transmission. Some people are able to snake their hands above the transmission while it is in place, but if you're not familiar with what's going on, that may end just being frustrating.
78 924 NA
5-lug
Jakkq
PostPosted: Fri Jun 19, 2009 3:17 pm    Post subject: Reply with quote
Where can I order some new joints to replace? I'd rather have them before I drop the tranny.
Vince Ponz
PostPosted: Fri Jun 19, 2009 11:48 pm    Post subject: Reply with quote
oops
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock
Vince Ponz
PostPosted: Fri Jun 19, 2009 11:49 pm    Post subject: Reply with quote
Do not forget the shifter bar and the shifter. Sometimes they oval and you cannot get in the correct gear. Change all of the bushings.
While in the car remove the shifter cover and look inside. Check for loose parts.
79 931 Euro stock
88 924S SE
87 911 Targa stock
Jakkq
PostPosted: Sat Jun 20, 2009 7:58 am    Post subject: Reply with quote
That actually may be a problem. I was sitting moving the shifter and it actually hits something before it goes into the second gear which may be causing the grinding?
Also, what loose parts should I be keeping an eye for? And where specifically are the bushing located? Ive never worked with a shifter before.
I'll take a deep excavation when I get home tonight.
