CorsePerVita
Joined: 25 Jul 2008 Posts: 1068 Location: Redmond, OR
Posted: Sat Mar 14, 2009 9:56 am Post subject: Vacuum routing w/o emissions?? |
So i found some vacuum routing diagrams. However... i no longer have emissions, so everything that went with it and all the hoses are gone. I got new vacuum line, new ends so I could attach and seal them. I was wondering if anyone had a diagram for vacuum routing without the weird emissions routing.
I'm assuming the green tube coming from inside the fender is the "vacuum reservoir" and then i have 3 other spots for vacuum. Should I plug some of them? Do i need the vacuum amplifier even now that i don't have emissions?
F'in hate vacuum lines. _________________ - 1984 Porsche 944 2.5 N/A
- 1977 Porsche 924 2.0 N/A
- 1970 Porsche 914 1.7
- 1999 Ford ZX2
- 1999 Ducati 900SS
- 2005 Ninja 250r
- 1974 Kawasaki F7C
- 1975 Honda CB 360 Cafe |
Ozzie
Joined: 12 Mar 2005 Posts: 3772 Location: Townsville, Qld. Australia
Posted: Sat Mar 14, 2009 7:00 pm Post subject: |
This is all I have on mine
( I have re-routed the breather hose to the air box and sealed the join in the boots since) _________________ Porsche 924 1984 (UK import) NA
Its AUTO and its BLACK
Montego Black on black/red
CorsePerVita
Posted: Sun Mar 15, 2009 6:10 am Post subject: |
i have a 77' i'm not aware of an aux air valve? i'll look again. right now the only thing i have hooked up is from the throttle body to the distributor, the back of the distributor is going back into part of the intake manifold. _________________ - 1984 Porsche 944 2.5 N/A
- 1999 Ford ZX2
- 1999 Ducati 900SS
- 2005 Ninja 250r
- 1974 Kawasaki F7C
Ozzie
Posted: Sun Mar 15, 2009 7:39 am Post subject: |
This is a ROW car. Only has one line to the dist and AFAIK all car had an AAV if you have CIS. _________________ Porsche 924 1984 (UK import) NA
