Water drain battery tray
ReMo
PostPosted: Sun Feb 22, 2009 9:14 am    Post subject: Water drain battery tray Reply with quote
The battery tray has two water drains. One big in te middle of the tray and a little one in the corner. Who can tell me where the water leaves the car by the little drain in the front corner off the tray?
http://www.porscheforum.nl/album_pic.php?pic_id=41091
tj924
PostPosted: Sun Feb 22, 2009 9:20 am    Post subject: Reply with quote
Usually straight into the cabin I think
TJ
Silver '82 924 NA 5-Speed Manual
PostPosted: Sun Feb 22, 2009 11:01 am    Post subject: Reply with quote
front corner on mine drains out to engine side of firwall and drips off near engine mount.. Not sure about this one in the middle of tray as that will fall inside ontop of fuse relay box
1979 NA
my Porsches Arse!!!
ReMo
PostPosted: Sun Feb 22, 2009 9:31 pm    Post subject: Reply with quote
Thanks for the answers. But i'm right that there are two drain in the tray?
But i still can't find the end of the little drain in the corner.
PostPosted: Sun Feb 22, 2009 10:01 pm    Post subject: Reply with quote
3 drains total - two are easy to see - one at each side draining immediately forward through the firewall. One more closer to the center, near the wiper motor on my car. This one drains through a tube that passes through the behind-under-dash area and exits through the front of the firewall behind the intake plenum. All 3 drains are the same size. If you're seeing one smaller than the others, maybe it's not an OE factory drain..?
ReMo
PostPosted: Sun Feb 22, 2009 11:29 pm    Post subject: Reply with quote
The hole car is original. But when you standing before the car there is a smal hole in the baterry tray in the left, front corner, like on the photo.
The tree other drains are oke.
I think i have to close that drain/hole.
