924guy
Posted: Sat May 09, 2009 10:26 pm Post subject: |
i think im going to frame one of these and hang it on my living room wall.... _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha |
Posted: Sat May 09, 2009 10:48 pm Post subject: |
gegge wrote: | Thanks Ideola, you are a star! Did receive the gaskets yesterday
You are doing a great job for the 924 community and your efforts are much appreciated. |
X2 _________________ 1979 NA
my Porsches Arse!!! |
Posted: Mon May 25, 2009 10:11 am Post subject: |
Good news:
They fit.
Bad news:
Not quite.
Although these are headers, don`t think the stock manifolds are any smaller. This shows the front riveted piece, the rear one also interferes. Suggest checking that your manifold does not hang any lower than the head face, and fixing it BEFORE you install it.
Also on the intake side the front rivet also fouls. Ground a mm or 2 off the manifold in this spot. If your head has not been machined much you may not have any issues.
Good news is:
They Work! |
Posted: Tue May 26, 2009 2:35 am Post subject: |
Ugh.
Posted: Tue May 26, 2009 2:44 am Post subject: |
yea..........
Realized that after the head was torqued down so knocked the tabs down with a bit of flat bar and hammer. Not ideal.
Discussed this with Peterld earlier and they do interfere on a stock 931 manifold. The tabs and rivets hold the layers together and more importantly in alignment. Should be able to get away with carefully cutting off the 2 on exhaust side. Easy on an engine stand but a PITA to do in the car. |
Posted: Tue May 26, 2009 4:21 am Post subject: |
We need some feedback from Cometic on this. I am very surprised this was never considered during development.
tuurbo
Joined: 08 Aug 2007 Posts: 1446 Location: East Windsor, New Jersey
Posted: Tue May 26, 2009 4:40 am Post subject: |
I don't get it. I'm looking at a stock head gasket 931 104 337 06 and there are no tabs with rivets.
Why would the company include those tabs? _________________ 1980 924 turbo, MSD, Meth. Inj, otherwise stock. |
Posted: Tue May 26, 2009 4:54 am Post subject: |
It is a multi-layer steel gasket. So it is made up of multiple layers of steel which are riveted together to provide alignment of the layers.
I've test fitted my engine together, but I didn't notice this issue with my header. The header interfered with the starter heat shield. I'll go out to the garage and take a peak to see if perhaps I missed it. _________________ Stefan
tuurbo
Posted: Tue May 26, 2009 5:28 am Post subject: |
Gotcha. Thanks. So if you cut one of these tabs off the alignment of the layers can go 'off'. _________________ 1980 924 turbo, MSD, Meth. Inj, otherwise stock. |
Shurick
Joined: 15 May 2005 Posts: 524 Location: Russia, Moscow.
Posted: Tue May 26, 2009 6:38 am Post subject: |
If I'm guessing right, those MLS gaskets are disposable. And tabs with rivets are only to hold the layers together till your gasket is tighten up. Once it is in place, you can cut the tabs and it will not affect the sealing or anythyng else.
Although it's an issue that must be solved, it's not a big mess. _________________ WBR, Shurick
'86 924S -- R.I.P.
https://www.instagram.com/ru_pacecar/ |
Posted: Tue May 26, 2009 7:10 am Post subject: |
I'll contact Cometic tomorrow and ask for a recommendation. And for the record, the gaskets are NOT reusable, according to my source at Cometic. _________________ erstwhile owner of just about every 924 variant ever made |
Shurick
Posted: Tue May 26, 2009 7:36 am Post subject: |
ideola wrote: | the gaskets are NOT reusable |
So we can freely cut those tabs once the gasket is tighten up. _________________ WBR, Shurick
'86 924S -- R.I.P.
Posted: Tue May 26, 2009 8:23 am Post subject: |
ideola wrote: | I'll contact Cometic tomorrow and ask for a recommendation. And for the record, the gaskets are NOT reusable, according to my source at Cometic. |
is that because they want more group buys from us?
im sure if the rivets were moved by cometic to be "inbetween" each exhaust hole it should work...dont really wanna cut mine _________________ 1979 NA
!tom
Joined: 28 Aug 2006 Posts: 1931 Location: Victoria, BC Canada
Posted: Tue May 26, 2009 8:37 am Post subject: |
Scorpio wrote: | is that because they want more group buys from us? |
I've never heard of a reusable head gasket myself before -- why would you expect this high performance one to be different? _________________ 78 924 NA
5-lug |
Joined: 10 Dec 2006 Posts: 946 Location: Noosa Heads QLD Australia
Posted: Tue May 26, 2009 8:40 am Post subject: |
Guys, its no big deal. Once the head is torqued down, it is a simple matter to bend the rivet ear out of the way. At worst it could be cut off as the head gasket is in place and secured. |
