xpernet
Joined: 07 Apr 2004 Posts: 414 Location: Kitchener, Ontario Canada
Posted: Sun Jan 25, 2009 3:39 am Post subject: EFI Project Update & Questions [UPDATE: IT RUNS!] |
I started converting the car into EFI sometime in October... but ive been really busy. However i got a lot of time on my hands now and im almost done
So far, ive got the MSII wired up and the EDIS. Tested both and they work like a charm... But i cant get the car to run. Ive got everything hooked up except for the Coolant Sensor because i forgot to buy one Would that be contributing to my no-start problem? I also tried increasing the PW for cold crank... but nothing. I know i have spark, and im getting fuel to the injectors so it seems like a SW issue to me.
Here are some pics... sorry about the mess... enjoy
 _________________ 1977 Porsche 924
Sunroof Delete
Megasquirt II EFI & EDIS
Carrera GTS / 944 Body
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Rich H
Posted: Sun Jan 25, 2009 5:20 am Post subject: |
Back to basics - fuel, spark, air.
Is there any fuel going in?
Is the spark firing near 10 deg BTDC? (Put a timing light on it)
Is the idle screw open? _________________ 1994 Lotus Esprit S4 - Work in progress...
Min
Posted: Sun Jan 25, 2009 6:03 pm Post subject: |
Looking good for sure, I'd get a coolant sensor as soon as possible, since that could definitely effect your startup. It probably isn't the sole cause for not starting, but it won't help you any when attempting to troubleshoot whats going on. Verify fuel on all the injectors, and verify spark on all the spark plugs, I had issues with both those things during my initial setup, one of my injectors wasn't firing, and half my spark plugs weren't, I figured this out by testing the spark plugs out on the valve cover, and pulling the rail out and checking for fuel spraying out of all of them on crank. From there, back to basics like rich said, fuel spark, air, and timing.
Rich H
Posted: Sun Jan 25, 2009 8:27 pm Post subject: |
I would also rejisit your crank sensor, that bracket will flex and the sensor will hit the wheel, it needs to be pretty stiff. Mine isn't great but it is very stiff.
Anyone got a decent mounting solution? I want to beef mine up. _________________ 1994 Lotus Esprit S4 - Work in progress...
xpernet
Posted: Mon Jan 26, 2009 6:09 am Post subject: ! |
Thanks for the replies... i was pretty frustrated after all this work and she still wouldnt want to start. Im getting spark, but my injectors arent spraying... MS shows its firing them but nothing is happening. Im crossing my fingers that its nothing major... gotta do some more testing so stay tuned! _________________ 1977 Porsche 924
Sunroof Delete
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche |
xpernet
Posted: Mon Jan 26, 2009 6:55 am Post subject: |
ok... so i hooked up my volt meter to my injectors, the resistance is up to spec. The MS unit is giving me like 4mv to the injectors. Does that sound right? To me it sounds like the injectors are gummed up... picked em up from an old Ford V8 from the mid 90s at the wreckers. _________________ 1977 Porsche 924
Sunroof Delete
Min
Posted: Mon Jan 26, 2009 11:52 am Post subject: |
| xpernet wrote: | | ok... so i hooked up my volt meter to my injectors, the resistance is up to spec. The MS unit is giving me like 4mv to the injectors. Does that sound right? To me it sounds like the injectors are gummed up... picked em up from an old Ford V8 from the mid 90s at the wreckers. |
Are your injectors high impedance or low?
xpernet
Posted: Mon Jan 26, 2009 11:54 am Post subject: |
Yup, 15ohms. _________________ 1977 Porsche 924
Sunroof Delete
Posted: Mon Jan 26, 2009 3:26 pm Post subject: |
| xpernet wrote: | | ok... so i hooked up my volt meter to my injectors, the resistance is up to spec. The MS unit is giving me like 4mv to the injectors. Does that sound right? |
It doesn`t SOUND right at all. However it is not DESCRIBED right either.
The MS unit doesnt "give" anything, it grounds one side of the injector, ie. shorts it to earth, ground, -Ve. The other side of the injector should have a nominal 12V with ignition on.
So was that 4mV ACROSS the injector (between the 2 terminals) or from the MS side to ground? Suggest you spend a little more time reading the megamanual and consulting the external wiring diagram for more understanding. Your problem may then have an obvious cure.
| Quote: | | To me it sounds like the injectors are gummed up... picked em up from an old Ford V8 from the mid 90s at the wreckers. |
You have given no information to lead to that conclusion. Just your assumption. IMO it is very highly unlikely that all 4 are seized, 1 possibly. If it actually is a fuel supply problem more chance of FPR, filter, etc. So do you have good flow of fuel at 42 PSI?
Back to basics-
Do you have a tach signal? - RPM reading on MT tacho of a few hundred RPM while cranking.
Does FP run for 2 seconds (prime) at switch on?
Good progress so far anyway.
Keep at it and remember "when all else fails, read the instructions."  |
xpernet
Posted: Tue Jan 27, 2009 8:29 am Post subject: |
| RC wrote: | | The MS unit doesnt "give" anything, it grounds one side of the injector, ie. shorts it to earth, ground, -Ve. The other side of the injector should have a nominal 12V with ignition on. |
I feel like an idiot not checking the wiring diagram before testing lol... Im getting 12 volts on BOTH terminals for the injectors... is that normal?!?!
| RC wrote: | You have given no information to lead to that conclusion. Just your assumption. IMO it is very highly unlikely that all 4 are seized, 1 possibly. If it actually is a fuel supply problem more chance of FPR, filter, etc. So do you have good flow of fuel at 42 PSI?
Back to basics-
Everything else runs, im cranking around 200rpm, i have spark on all cylinders, and have enough fuel pressure that i shot one of my injectors out the fuel rail while testing for spray lol... _________________ 1977 Porsche 924
Sunroof Delete
Min
Posted: Tue Jan 27, 2009 10:20 am Post subject: |
Ok, at this point you need to test functionality of your fuel injectors. The way I would do this is to run power to one side of the injector, and ground the other side very briefly on your battery, when you tap the wire it should open the injector. If this works on all of your injectors, try the megasquirts injector test mode.
you need to determine were the problem lies, so, by testing the injectors without the megasquirt, you can determine if there is a injector issue, or a megasquirt issue.
Posted: Tue Jan 27, 2009 10:23 am Post subject: |
| xpernet wrote: |
I feel like an idiot not checking the wiring diagram before testing lol... Im getting 12 volts on BOTH terminals for the injectors... is that normal?!?! |
What do you mean "getting 12 volts ON BOTH TERMINALS"?? Where exactly are you placing your multimeter probes? With ignition on you should see 12V on one side as RC mentioned. Only when the injector is actually firing will you see 12V across the terminals - as MS grounds the other side, causing voltage to flow and the injector to open...
69 911 |
xpernet
Posted: Tue Jan 27, 2009 10:56 am Post subject: |
I placed the negative probe to the car's body and positive to the Injector Wire... I know how to use a multimeter its part of my job ... I get 12volts when the ignition is on and nothing when the car is off. It doesnt make sense to me, i traced the wires back to MS and there is no short anywhere. Even if there was a short it should have popped my fuse!
To make stuff more bizzare, as soon as i unplug the injectors i only get 12v on the live wire and nothing on the wire going to MS. As soon as i plug an injector in, i get positive on both wires!! _________________ 1977 Porsche 924
Sunroof Delete
Posted: Tue Jan 27, 2009 11:31 am Post subject: |
Use a 12V test lamp on both and tell us what you see. _________________ White 87 924S "Ghost"
Posted: Tue Jan 27, 2009 11:38 am Post subject: |
| pocketscience wrote: | | xpernet wrote: |
Yes. Assume you are measuring from EACH injector terminal to ground and getting 12V with ignition on. This is "normal" if MS is NOT activating the drivers and grounding pins #32-35 (on DB37) to earth. It will not be a direct short to earth due to the FET`s internal resistance but should be < 0.5V above ground. Or in simple terms.....MS aint working.
Not sure if you have V2.2 or V2.3, however the injector wiring is similar. Hopefully you used different coloured wires to the injectors so you KNOW which one is +12V and which one is switched (grounded by MS). To test injectors suggest first removing the fuse to MS only (you did wire up fuses like in the diagrams?) then switch ignition on and jump (run a wire) from the switched injector terminal to ground (engine) momentarily. Should hear a click and possibly fuel flowing from residual pressure.
Hopefully the injectors check out OK since your problem appears to be here:
| Quote: | | But i cant get the car to run. Ive got everything hooked up except for the Coolant Sensor because i forgot to buy one Would that be contributing to my no-start problem? |
Megamanual says:
| Quote: | Temperature Sensors
MegaSquirt uses coolant and air temperature sensors to determine the warm-up characteristics of the engine and the density of the intake air. They are essential to proper functioning of a MegaSquirt® controller. |
Now according to the GM sensor temp Vs resistance chart, -40*C equates to around 100Kohms. However with no sensor you have an infinite resistance, well over many Mohm (megaohm,). Can you appreciate that MS "sees" a temp approaching absolute zero (-273C) or some other non existent value, depending on the programming.
Look here as it doesn`t format by copying.
http://www.megamanual.com/v22manual/mwire.htm#clt
So get a temp sensor. Personally suggest a GM one as it makes things much easier and more accurate in the long run.
As a basic experiment you could substitute a fixed value resistor of approximate temp value. Considering your location, 10K is a reasonable guess. However if you have to go out to get one, don`t bother, just get the sensor.
Trust this helps. |
