Joined: 01 Oct 2004 Posts: 15487 Location: Woodstock IL
Posted: Fri Nov 28, 2008 5:20 pm Post subject: Comprehensive Suspension Bushing Upgrade Guide |
Here is my attempt to identify all (or at least most) of the available options for upgrading our suspension bushings based on stock 924/944 suspension components (i.e. this does NOT include all of the available aftermarket sway bar options).
http://garage.ideola.com/top-Downloads.html
Left column, the link entitled 924/944 Suspension Bushing Analysis.
It's interesting that for many of the sway bar components, there are apparently NO available poly or delrin replacements, so depending on what you have on your setup, you might have to settle for OEM rubber replacements. As for the major components, since I've collected a variety of suspension bits from various donors, I'm still puzzling thru which combination I want to put together. The other question is whether to go with full monoball / solid mount ($$$$$pendy) or settle for Delrin / Poly for now and upgrade to the monoball stuff later. TBD, but in the meantime, I thought this might be useful to some of you guys as well.
As always, feedback welcome.
{EDIT}
See also: SUSPENSION, BRAKES, WHEELS & TIRES (Performance Upgrades) _________________ 15 981 GTS | 88 924S SE | 82 931 Holbert | 82 931 Rallye | 81 937 | 81 Euro 931 | 81 Weissach | 80 US 928 | 80 US 931 '941' | 80 US 931 | 80 931 GTR | 79 Sebring | 78 D-Prod Replica | 78 w/D-Prod kit | 78 Poli-Form | 78 Limited Edition | 77 Martini
Joined: 05 Jul 2007 Posts: 1956 Location: Brisbane, Australia
Posted: Fri Nov 28, 2008 5:48 pm Post subject: |
Do you sleep?  _________________ 1979 NA
my Porsches Arse!!! |
Posted: Fri Nov 28, 2008 6:33 pm Post subject: |
Scorpio wrote: | Do you sleep?  |
yea...do you ever sleep?
thanks for the analisys Dan, it sure is usefull ! _________________ red 924 and not red 924 |
924guy
Joined: 29 Dec 2003 Posts: 2091 Location: Port St. Lucie, FL
Posted: Sat Nov 29, 2008 12:07 am Post subject: |
nicely done... this is a great tool! as usual, awesome work!
i would like to see bugpak/prothane cross referenced in there as well, as many of their poly bushings are directly compatible. maybe some one here has some p/n's that we can just plug in? _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha |
Posted: Sat Nov 29, 2008 12:59 am Post subject: |
924guy wrote: | bugpak/prothane |
Hmmm...a quick search didn't yield any suppliers...post some links and I'll follow up on it. _________________ 15 981 GTS | 88 924S SE | 82 931 Holbert | 82 931 Rallye | 81 937 | 81 Euro 931 | 81 Weissach | 80 US 928 | 80 US 931 '941' | 80 US 931 | 80 931 GTR | 79 Sebring | 78 D-Prod Replica | 78 w/D-Prod kit | 78 Poli-Form | 78 Limited Edition | 77 Martini |
Posted: Sat Nov 29, 2008 4:37 am Post subject: |
Prothane poly control arm bushing kit is Prothane 22-201.
There are a ton of suppliers, HERE IS ONE.
Oh, and with your sway bar parts list you may want to add the factory rear mount, 477 501 095. _________________ Toofah King Bad- Shaggy (1980 931) - Got Boost?
- Weiße Scheiße (1987 924S) - In Progress
Posted: Sat Nov 29, 2008 4:48 am Post subject: |
OK, will do, thanks! _________________ 15 981 GTS | 88 924S SE | 82 931 Holbert | 82 931 Rallye | 81 937 | 81 Euro 931 | 81 Weissach | 80 US 928 | 80 US 931 '941' | 80 US 931 | 80 931 GTR | 79 Sebring | 78 D-Prod Replica | 78 w/D-Prod kit | 78 Poli-Form | 78 Limited Edition | 77 Martini |
Min
Joined: 04 Nov 2002 Posts: 2365 Location: Vernon, British Columbia, Canada
Posted: Sat Nov 29, 2008 1:03 pm Post subject: Re: Comprehensive Suspension Bushing Upgrade Guide |
ideola wrote: | It's interesting that for many of the sway bar components, there are apparently NO available poly or delrin replacements |
I can make them.
Posted: Fri Dec 05, 2008 12:55 am Post subject: |
I have just posted a major update to the SUSPENSION, BRAKES, WHEELS & TIRES section of the Performance Upgrades thread. Rather than repeating that information here, and needing to maintain it in two places, please use the cross reference to gather more information about the various permutations and considerations for bushing upgrades. _________________ 15 981 GTS | 88 924S SE | 82 931 Holbert | 82 931 Rallye | 81 937 | 81 Euro 931 | 81 Weissach | 80 US 928 | 80 US 931 '941' | 80 US 931 | 80 931 GTR | 79 Sebring | 78 D-Prod Replica | 78 w/D-Prod kit | 78 Poli-Form | 78 Limited Edition | 77 Martini |
Posted: Fri Dec 05, 2008 2:01 am Post subject: |
Rasta Monsta wrote: | Prothane poly control arm bushing kit is Prothane 22-201.
There are a ton of suppliers, HERE IS ONE. |
Upon a quick investigation, it appears to me that the Prothane stuff is only available for the front A-arms. I have changed what I originally identified as EuroSport (which is just one reseller) to Prothane.
Rasta Monsta wrote: | Oh, and with your sway bar parts list you may want to add the factory rear mount, 477 501 095. |
Regarding the rear trailing arm clip, I've added that into the spreadsheet, noting that it is only required if your car did not ship with a factory installed rear sway bar. _________________ 15 981 GTS | 88 924S SE | 82 931 Holbert | 82 931 Rallye | 81 937 | 81 Euro 931 | 81 Weissach | 80 US 928 | 80 US 931 '941' | 80 US 931 | 80 931 GTR | 79 Sebring | 78 D-Prod Replica | 78 w/D-Prod kit | 78 Poli-Form | 78 Limited Edition | 77 Martini |
Posted: Tue Dec 16, 2008 5:15 am Post subject: |
FWIW, there is another supplier in this space, a seller on eBay called "fastechracing". They recently had the upper torsion wing mounts and a set of rear sway arm mono ball bushings listed, and I've seen them list the solid Audi-based trans mounts as well (I think...either that or the upper torsion mount, can't remember). In any event, I've exchanged emails with them, and they claim to be manufacturing their own product, as well as working on a wider range of offerings. I have yet to see exactly what they're offering, but I've updated the spreadsheet with the torsion wing mount and sway arm bushing. The prices they've listed on eBay have been VERY competitive...in fact, the lowest I've seen for solid / monoball stuff. Again, FWIW. _________________ 15 981 GTS | 88 924S SE | 82 931 Holbert | 82 931 Rallye | 81 937 | 81 Euro 931 | 81 Weissach | 80 US 928 | 80 US 931 '941' | 80 US 931 | 80 931 GTR | 79 Sebring | 78 D-Prod Replica | 78 w/D-Prod kit | 78 Poli-Form | 78 Limited Edition | 77 Martini |
Joined: 23 Apr 2006 Posts: 1648 Location: Sydney, Australia... mate!
Posted: Sat Aug 08, 2009 12:07 am Post subject: |
New link that works... here
94 993 |
PieszczoH
Joined: 03 Dec 2009 Posts: 57 Location: Warsaw Poland
Joined: 29 Jul 2001 Posts: 8063 Location: Royal Oak, MI, USA
Posted: Tue Dec 08, 2009 11:52 pm Post subject: |
Go for some variety of plastic, not sphericals. Spherical bearings, lacking any compliance, will do ugly things to your unibody on streets, especially Detroit streets. You won't lack anything for performance by going with Delrin. _________________ Vaughan Scott
