A/F
Mudd
PostPosted: Fri Jul 12, 2013 1:07 am    Post subject: A/F Reply with quote
Where is the A/F mixture adjusting screw on a 1978 924.
1987 944
staticsan
PostPosted: Fri Jul 12, 2013 4:48 pm    Post subject: Reply with quote
It's down inside the air-mass meter, underneath the fuel distributor. There's a port to get to it between the boot over the meter plate and the fuel distributor. You will need a 3mm Allen key that is at least 6 inches long.
The Haynes book tells you in more detail, including pictures.
Wade.
'82 British NA - Which I think I've been very lucky with!
scriblz7
PostPosted: Fri Jul 12, 2013 6:34 pm    Post subject: Reply with quote
do not go adjusting your mixture unless you know you have no vacuum leaks, and you have the correct fuel control and system pressures. it will just make things more wonky.
Riley
79 924 n/a with gt body
15 VW GTI
ThomasJoseph315
Guest
PostPosted: Fri Jul 12, 2013 6:55 pm    Post subject: Reply with quote
You really don't wanna fiddle with this thing unless you know what your doing. As scribles said, check for vacuum leaks. I had leaks all over. Check the injector seals, and the warm up injector gasket, and of course vacuum lines. Get a can of brake cleaner and go nuts. Trying to make your A/F work for you when you got leaks is pointless. Also, when adjusting, I have installed a A/F gauge in my car. I suggest you do the same. Total cost for me was under $150 for a narrow band. $50ish for gauge, $20 for O2 sensor, and $60 to weld it in. I would be lost without this little guy. I may just upgrade to a wide band one soon, prolly next month.
Mudd
PostPosted: Sat Jul 13, 2013 12:54 am    Post subject: Reply with quote
I am going to clean my WUR and I have been screwwing with the air bypass screw, so after the WUR is clean I figure I will have to adjust something to get my idle correct. I replaced all of the vacuum lines and am pretty confident I don't have any vacuum leaks.
1987 944
ThomasJoseph315
Guest
PostPosted: Sat Jul 13, 2013 3:04 am    Post subject: Reply with quote
I cleaned mine without disassembling it, but check the heater for ohms. I would pull the screens out on the larger line, mine had 5 screens that where all clogged up. Then you'll see the small holes where the gas goes though. Blast that thing with car/brake cleaner. Mine was definitely clogged as it took a few times then I seen a ton of black grime come out.
Good luck!
scriblz7
PostPosted: Sat Jul 13, 2013 7:52 am    Post subject: Reply with quote
like i said earlier, once your wur is clean you will have to check your fuel system and control pressures. those will more than likely be out of spec. get those in spec and then if you have to can mess with the idle control on the throttle body and the a/f ratio.
Riley
15 VW GTI
Brockoli
PostPosted: Sat Jul 13, 2013 11:44 am    Post subject: Reply with quote
i bought the innovate mtx-l wideband o2 sensor. i think i paid about $180 for it. heres an ebay listing for one...
http://www.ebay.ca/itm/INNOVATE-3844-MTX-L-DIGITAL-WIDEBAND-AIR-FUEL-GAUGE-KIT-/370520832034
It is easy to install especially if your car came with an O2 sensor, my '80 did. This sensor is pretty good, it even can output a narrow band signal that you can wire back into the fuel system to keep the frequency valve operational. I didnt, I think when the frequency vavle is unplugged the car runs 50:50, meaning it doesnt lean out or get richer, which was nice for tuning as I just adjust the fuel mixture screw.
staticsan
PostPosted: Mon Jul 15, 2013 8:04 pm    Post subject: Reply with quote
Oh yes. Adjusting mixture and idle speed is an iterative process, too. Change one, and you will probably need to move the other. And _any_ vacuum leaks will mean changed to either mix and idle pointless at best and highly dangerous at worst.
Wade.
