Mike B Guest
Posted: Sun Sep 02, 2001 1:47 am Post subject: |
I recently, with Vaughan's guidance, completed the upgrade to 4 wheel disc brakes on a '78 924...I used the parts from an '80 931 with the m471 option...
My problem is the brake booster seems to have a vacuum leak so it must be replaced...My trusty parts catalog shows the booster with part number 477-612-107F for '80 (with m471) & '81-'82 924 with the same part number...
Ideally I would like to pick up the same booster but, if I can't find one, can I use a booster from an early 944 instead???? If so which one is better...The Girling or ATE...Any help is appreciated and better yet anyone has a booster (477-612-107F) I would be interested... |
Mike B Guest
Posted: Wed Sep 05, 2001 4:24 am Post subject: |
| .....help..... |
kaffine krazed Guest
Posted: Wed Sep 05, 2001 7:37 am Post subject: |
Are you sure the vacuum booster is leaking?
From reading the diffrent parts catalogs the ATE and Gerling vacuum boosters are not interchangeable with the master cylinder. So if you have a ATE master cylinder you can't put a Gerling vacuum booster in without changing the master cylinder to a Gerling as well. |
Mike B Guest
Posted: Wed Sep 05, 2001 9:34 am Post subject: |
The master cylinder was a direct replacemment...same part number for the donor brake system from the '80 931 as was there...The symptoms are:...brakes work fine with no pedal fade while the car is moving and the rpms are above idle...At a stop light, when the car is idling, the pedal begins to fade and drop to the floor but stops short of the floorboards...As soon as I increase the rpms the pedal firms up again...The only time the pedal fades is when it is stopped otherwise it is firm and the brakes work great...A local garage, where my son used to work, stated the booster had a vacuum leak and would need to be replaced...
I don't know but the diagnosis seems reasonable...Anybody..Vaughan??? |
Posted: Wed Sep 05, 2001 11:18 am Post subject: |
True, but make sure you've got it plumbed right (for vacuum)... sorry, no spares at all for the brakes...
Mike B Guest
Posted: Thu Sep 06, 2001 8:18 am Post subject: |
Will an early 944 booster work in place of this ATE model or should I find the same one...
I'll check all the connections but I think it is hooked up correctly... |
pst Guest
Posted: Fri Sep 07, 2001 2:47 am Post subject: |
| As long as the master cylinder fits the booster you can use it. Basically, there are two different boosters. A 7" and a 9". The 7" was used up to 1979 and had a slightly smaller bore master cylinder, the 9" had a slightly larger bore master cylinder. You can interchange the boosters and you won't notice much difference. |
Mike B Guest
Posted: Fri Sep 07, 2001 7:22 am Post subject: |
| Thanks for the replys |
Posted: Sun Sep 09, 2001 4:41 pm Post subject: |
I don't think it's your brake booster. If it had a vacuum leak the pedal would be hard not soft.
