Fuel Pump Question
gla924sem
PostPosted: Fri May 25, 2012 11:42 pm    Post subject: Fuel Pump Question Reply with quote
Going to install a fuel cell in the #27 using the stock gas tank to accept the cell.
The 1982 tank has a fuel pump in the tank and on the right rear fender well
The fuel cell will eliminate the fuel pump in the tank
Can I get away using only the fender fuel pump or will I need to upgrade to an afteermarket?
Arvidw
PostPosted: Sat May 26, 2012 7:16 am    Post subject: Reply with quote
If you make sure the stock fuel pump is mounted below the lowest fuel level of the fuel cell you should be fine.
Porsche 924 2.0 Kompressor 136.1wHp @ 5650rpm / 201.9wNm @ 3900rpm (dyno @ dp-engineering.nl)
PostPosted: Sat May 26, 2012 4:37 pm    Post subject: Reply with quote
for racing, you could use a second pump and a catch tank.
