Joined: 01 Oct 2004 Posts: 10339 Location: Plymouth MI
Posted: Thu Sep 04, 2008 2:19 pm Post subject: Why hasn't the topic of phenolic spacers come up before??? |
Seems like a really good idea, especially on boosted applications. Also seems like it would be VERY easy to implement on our cars, as there is no need for a TB spacer, only the intake spacer. Added bonus is that they would be universal across the NA & Turbo cars.
Reading material:
http://www.autospeed.com/cms/A_110474/article.html
Any body else interested if I can find a manufacturer (I already have one in mind...)? _________________ ideola's garage
Unique Products, Used Parts, Group Buys & Downloads for the Porsche 924, 944 and 928
Visit our CarDomain site |
Joined: 03 Nov 2002 Posts: 9285 Location: Richmond BC. Canada
Posted: Thu Sep 04, 2008 3:59 pm Post subject: |
keep in mind phenolic is VERY expensive. _________________ 3 928s,
and a VW golf (diesel) |
Joined: 23 Apr 2006 Posts: 1608 Location: Sydney, Australia... mate!
Posted: Thu Sep 04, 2008 4:48 pm Post subject: |
| Lizard wrote: | | keep in mind phenolic is VERY expensive. |
| Quote: | | Several companies, including Ford Motorsport, offer insulators for 5.0L Mustang owners as well as for carburetted applications - just look through a Summit Racing catalog!. The most common thicknesses are 3/8 -1 inch and prices are generally in the US$50-$60 range |
Of course a custom job would be more it shouldn't be too unreasonable...
Put me down Dan!
81 924 N/A
Done: GTS lights, Saratoga, interior, headers, Integral cam, EFI
Doing: 5-lug
To do: SC, CGT kit, wheels! |
Posted: Thu Sep 04, 2008 8:00 pm Post subject: |
I don't know yet about the material in bulk, but the online prices for a COMPLETE kit seems to be between $50-$120 depending...some on the upper end include spacers for V setups (i.e. two manifold spacers, one for each side), plus multiple throttle bodies, plus multiple gaskets, plus extended studs or bolts. Doesn't seem cost-prohibitive to me, and based on the potential benefits seems worthwhile on a boosted car... _________________ ideola's garage
gegge
Posted: Thu Sep 04, 2008 9:15 pm Post subject: |
Interested!
Might just be one of the best bang-for-the-buck ever!!
7hp and 17-29 deg Cels drop in temerature on a N/A small V6 indicates minimum the same on a turbo, probably a lot better since intake temperaturs on the turbo is way higher under boost!!! _________________ Carl Fredrik Torkildsen
924 Carrera GT -81 (replica)
CGT IC, GTS turbo, UTCIS, Fuchs & R888, Leather Recaros, LSD, LEDA suspension... |
Posted: Thu Sep 04, 2008 9:34 pm Post subject: |
if it drops the temps...i'm in too.  _________________ 924 Carrera 1.0bar == grin factor. 10/10;
932 K27 - WIP
http://www.cardomain.com/ride/3181205 |
Joined: 29 Jul 2001 Posts: 6999 Location: Royal Oak, MI, USA
Posted: Thu Sep 04, 2008 9:45 pm Post subject: |
| ideola wrote: | | I don't know yet about the material in bulk, but the online prices for a COMPLETE kit seems to be between $50-$120 depending...some on the upper end include spacers for V setups (i.e. two manifold spacers, one for each side), plus multiple throttle bodies, plus multiple gaskets, plus extended studs or bolts. Doesn't seem cost-prohibitive to me, and based on the potential benefits seems worthwhile on a boosted car... |
We had this discussion, it's all about volume...
I would imagine that it'd be perhaps easier to do it in Delrin... _________________ Vaughan Scott
Hidari Firefly DSR (hitting the track in '10!)
Yadda yadda yadda... |
Posted: Thu Sep 04, 2008 9:51 pm Post subject: |
Yeah, I don't care so much if it's phenolic or Delrin, but the concept itself (that of a manifold insulator) seems to be pretty sound. Vaughan, I'll add this to the list, and we'll discuss on Saturday  _________________ ideola's garage
tuurbo
Joined: 08 Aug 2007 Posts: 1458 Location: East Windsor, New Jersey
Posted: Thu Sep 04, 2008 11:57 pm Post subject: |
Good article!
Please count me in!
I have a question - here's a quote:
| Quote: | Phenolics, with excellent insulating properties, high stiffness, and the ability to withstand 500+ degrees F (260 degrees C), are commonly chosen for similar applications. Additionally, the coefficient of thermal expansion of a phenolic is similar to that of aluminium, which helps to reduce sealing problems in this particular use.
When compared to the 0.025 inch steel gasket it replaces, a quarter inch thick phenolic insulator will conduct 200-1000 times less heat! Although the insulation benefits increase with thickness, ¼ inch (6.4mm) sheet was chosen because this is the thickest that can generally be used with stock mounting studs and bolts. |
So what would be the ideal thickness for our purposes - and what's the advantage of the same studs? Why not just size up new studs to fit the spacer?
Also, can these spacers, if they're like an inch thick, be tapped? Could they hold a nozzle or injector? Or have I lost my bearings here?
Thanks! _________________ 1980 924 turbo, MSD, Meth. Inj, otherwise stock. |
Joined: 25 Mar 2007 Posts: 2141 Location: Coffs Harbour, Australia
Posted: Fri Sep 05, 2008 12:12 am Post subject: |
OK Dan, I`ll be in for one now you`ve got the ball rolling.
Should be easy and realistically priced by having a small run done on a CNC router. Very common these days as most plastics shops and bigger sign shops have them, as well as some specialist light engineering shops catering for electronic manufacturers. They can scan a gasket and write the program from that. How many can you fit on a 8 x 4 sheet?
Studs are no problem at all. I made mine using a length of M8 threaded rod (booker rod, all thread) and a hacksaw. Looks great, won`t rust, and has a low coefficient of thermal conductivity. |
Posted: Fri Sep 05, 2008 12:16 am Post subject: |
| RC wrote: | Should be easy and realistically priced by having a small run done on a CNC router. Very common these days as most plastics shops and bigger sign shops have them, as well as some specialist light engineering shops catering for electronic manufacturers. They can scan a gasket and write the program from that. How many can you fit on a 8 x 4 sheet? |
Exactly what I was thinking. _________________ ideola's garage
924aussie
Joined: 02 Feb 2006 Posts: 611 Location: Australia queensland brisbane
| Quote: | | has a low coefficient of thermal conductivity. |
Sorry I am in Queensland , does that mean it doesnt get hot
Alan _________________ green 924 .. 1980 rego 924PSH
Fitted with a Web Based Live Vehicle Tracking System
so I can find the car in shopping centres among the 4WD's
alan@gpsnettrack.com.au
www.gpsnettrack.com.au |
924guy
Joined: 29 Dec 2003 Posts: 2053 Location: Port St. Lucie, FL
Posted: Fri Sep 05, 2008 12:19 am Post subject: |
I have considered this in the past, my ford probe responded very well to "pheno's" (at both the intake and tb) something I plan to investigate further down the road. I would think it would be fairly easy to determine if they would be worth the trouble by measuring the intake temp at the base of the manifold, then at the tb, have to see how much heat transfer were getting.
phono's generally reduce iat by 15 -40 degrees (depending on who you ask or what manufacture claims what.)
so id say a true iat reduction of of ten degrees or more would definitely be worth a bit of trouble, and we'd see a difference... _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha |
Posted: Fri Sep 05, 2008 12:33 am Post subject: |
Would dramatically reduce conducted heat but still be susceptible to radiated and absorbed heat being just below the hood in a hot engine bay. Would be worthwhile taking some measurements at the manifold and the ambient temp below the hood.
Forgot to mention before that I`m sure there is 2 different stud patterns, NA and turbo. IIRC there is about 5mm variation on some holes. Someone should compare gaskets if they have both. May require 2 templates/ programs or are you just looking at turbo ones? Possibly could look at a universal design using elongated slots? |
Posted: Fri Sep 05, 2008 12:47 am Post subject: |
Now that you mention it, I think you're right about the different patterns. No matter, I have examples of both intakes sitting around, so we can either examine different designs, or a universal slotted design (good idea, btw!). I think the biggest factor here will be the material itself. Scanning a couple of different gaskets and doing the design work is a one-time effort, so I don't see that adding a tremendous amount to the overall cost.
If my assumptions turn out to be true (after discussing with a manufacturer), it shouldn't be a big stretch to look at versions for the 2.5L as well. From my research, no one else is offering this yet for that platform either (although I haven't been exhaustive in my searches, just preliminary indications). Expanding to the 2.5L crowd should help drive demand and reduce the overall piece price. _________________ ideola's garage
