vemser
Joined: 06 May 2008 Posts: 46 Location: Russia, Moscow
Posted: Tue Sep 02, 2008 7:08 pm Post subject: Choosing turbo for my manifold |
Hi everybody!
I need your help with my manifold
European XK, VEMS EFI. I plan 0.5 bar boost.
Maybe you know some popular cheap turbos which will good for me.
The flange sizes writed later, sorry don't remember now. |
Raceboy
Posted: Wed Sep 03, 2008 12:20 am Post subject: |
Hard to tell from the picture, but it seems to be T3 flange. You could use K24 from Audi 20V turbo that is a good and cheap turbo or find Nissan Silvia S15/Skyline GTR T28R ball bearing/ceramic turbine wheel turbo that offers excellent response. They go for like 150-200 euros, K24 is going for around 100 euros max.
But it should be internally wastegated turbo! _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
vemser
Posted: Wed Sep 03, 2008 4:22 am Post subject: |
47*60 central hole
70*83 hols for mount |
vemser
Posted: Wed Sep 03, 2008 4:51 am Post subject: |
I checked garrett catalog for turbine flange's name, it's "T4"
Garrett's name GT3571 - Ok, but it's non-wastegated.
Looks huge  |
Posted: Wed Sep 03, 2008 4:58 am Post subject: |
The Audi K24 may not be what you want...it will run out of breath even sooner than the stock K26 units:
I'm sure you can find some combo of a T4-compatible hotside with a modern Garret setup that will be suitable in size, internally wastegated, and much more efficient than a KKK unit.
Care to share any details of your build? _________________ erstwhile owner of just about every 924 variant ever made |
vemser
Posted: Wed Sep 03, 2008 5:15 am Post subject: |
| It's just street car for dayly driwing. 200hp should be enough for stock pistons and clutch . |
Posted: Wed Sep 03, 2008 5:28 am Post subject: |
By my calcs, 200 HP on an otherwise stock build will require ~12 psi, which puts your air flow requirements in the neighborhood of ~17 cm^3/sec, with a pressure ratio of ~1.82. Looking at those numbers plotted on the above map, the Audi K24 just might do the trick... _________________ erstwhile owner of just about every 924 variant ever made |
vemser
Posted: Wed Sep 03, 2008 5:34 am Post subject: |
More details)
vemser
Posted: Wed Sep 03, 2008 5:42 am Post subject: |
| ideola, can you show your calcs, i'm not sure about 1.82, i think it's less... |
Posted: Wed Sep 03, 2008 5:55 am Post subject: |
| vemser wrote: | | ideola, can you show your calcs, i'm not sure about 1.82, i think it's less... |
Atmospheric Pressure (AP) = 14.7 PSI
Boost Pressure (BP) = 12 PSI
Pressure Ratio = (AP + BP) / AP
(14.7 + 12) / 14.7 = 1.82 _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Wed Sep 03, 2008 6:00 am Post subject: |
Nice pix, by the way
You might find my Engine Modification Horsepower Calculator thread somewhat useful. There is a downloadable excel spreadsheet linked there that contains all of the calcs.
In particular, take a look at Scenario 1 (in the screenshot of the spreadsheet posted there), and look at the 12 PSI setting, which should be fairly close to what you're targeting. _________________ erstwhile owner of just about every 924 variant ever made |
vemser
Posted: Wed Sep 03, 2008 6:01 am Post subject: |
Yee, the same result.
I'm looking in "maximum boost" page 26 and think about if. |
vemser
Posted: Wed Sep 03, 2008 6:07 am Post subject: |
| ideola wrote: | Nice pix, by the way
In particular, take a look at Scenario 1 (in the screenshot of the spreadsheet posted there), and look at the 12 PSI setting, which should be fairly close to what you're targeting. |
I have 924 XK engine, not turbo pistons. |
Posted: Wed Sep 03, 2008 6:15 am Post subject: |
Higher compression, I think, but shouldn't have a huge impact on overall targets, but will have to take into account for detonation...looks like you're planning to run a 951 FMIC, so I don't think you'll have too many problems at 12 psi. _________________ erstwhile owner of just about every 924 variant ever made |
Raceboy
Posted: Wed Sep 03, 2008 6:39 am Post subject: |
Actually K24 is better turbo than K26 as it's more efficient and is more than enough for turbocharging stock 924 NA. _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'84 928 S, sold
'91 944 S2, sold
