cakemakerman Guest
Posted: Sat Apr 27, 2002 4:54 am Post subject: |
I have found plenty of swap kits for the 944 but none for the 924. Does anyone know of a company that builds kits to swap v6s and v8s into 924s? I got this empty 1978 924 that either needs to be parted out or filled with an engine and driven to my new destination. |
wdb Guest
Posted: Sat Apr 27, 2002 7:34 am Post subject: |
I think putting a higher HP motor in a 924 would benefit from a tranny with better gearing for the higher HP. a tranny from 944,968, or 928 could be used , depending on the HP of the engine you'll be using. so the adaptor plate to mount a v6 to the 944 clutch assembly might just be what you need.
Rick MacLaren Guest
Posted: Mon Apr 29, 2002 11:18 am Post subject: |
Put a V12 in it man!
These V12's will shoehorn into a 924 and there are tons of them at wrecking yards for cheap. Trust me, you can do these for, like, under $1000. They make a 924 faster than a cat with his arse on fire!
http://www.ferrari-924conversions.com
The server is slow so just keep clicking 'Refresh' if it fails.
[ This Message was edited by: Rick MacLaren on 2002-04-29 12:18 ] |
Cbass Guest
Posted: Mon Apr 29, 2002 2:44 pm Post subject: |
I think you're on to something there, Rick. Maybe I was wrong about you scots
Rick MacLaren Guest
Posted: Tue Apr 30, 2002 2:21 pm Post subject: |
Just trying to keep up the spirits here CBass...
You know those 924 engines are rock solid. Have you considered the cost of making a rocket 924 engine? It's a bigger challenge...cheaper, and it ups your eligible resale market share...
[ This Message was edited by: Rick MacLaren on 2002-04-30 14:21 ] |
Cbass Guest
Posted: Thu May 02, 2002 4:44 pm Post subject: |
Actually, I was thinking about a propane conversion and 2 bars of boost No reason why it can't be done.
A solid rocket powered 924 would be fun, but I think the throttlem might be an issue |
turbobob924 Guest
924 turbo Guest
Posted: Mon May 06, 2002 11:37 am Post subject: |
None of the pictures are working on your site.
turbobob924 Guest
Posted: Sun May 19, 2002 8:59 am Post subject: |
Web site pictures S/B OK now... |
Rick MacLaren Guest
Posted: Tue May 21, 2002 10:26 pm Post subject: |
Propane is the best fuel for turbocharging. |
Lizard Guest
Posted: Tue May 21, 2002 10:33 pm Post subject: |
propane is only good with really high compression |
Rick MacLaren Guest
Posted: Tue May 21, 2002 11:43 pm Post subject: |
Exactly!
The problem I'd have with installing propane, and I've thought about it, is that you just can't access it easily. Like, where would ya fill up? A trailor park? |
Lizard Guest
Posted: Wed May 22, 2002 2:06 am Post subject: |
over in bc almost every gas station has propane |
friskynibbles Guest
Posted: Wed May 22, 2002 2:21 am Post subject: |
yep yep.
Lizard Guest
Posted: Wed May 22, 2002 2:34 am Post subject: |
and it is super cheap right now too |
