chad-tanner
Joined: 23 Mar 2008 Posts: 217 Location: New Madrid,MO
Posted: Sun Aug 03, 2008 9:38 pm Post subject: LSD |
I posted this in the general discussion by mistake,I had intended, to only post it here....I get lost sometimes...
Has anyone here converted their open diff to a true LSD,using a method such as this.
I bet you never seen this before
_________________ 77.5 Porsche 924/4.9L cadillac swap
Inspector: These brakes look completely inadequate.
Burt Munro: Well, I'm planning on going, not stopping. |
Posted: Mon Aug 04, 2008 1:34 am Post subject: |
technically a phantom grip unit iirc. _________________ 3 928s, |
alexvex
Joined: 31 Jul 2006 Posts: 420 Location: Seattle, WA (from Indiana)
Posted: Mon Aug 04, 2008 1:41 am Post subject: |
looks like a phantom grip....i'd never put one in my car though...do it right or not at all _________________ --Alex--
1992 Porsche 968 (VW 2.5L I5 Turbo swap in the works)
1995 Audi 90 Quattro Sport (4.2L V8 Swap)
2010 Touareg TDI
Past Pcars: 80 931, 87 924S, 87 951 |
chad-tanner
Posted: Mon Aug 04, 2008 1:59 am Post subject: |
alexvex wrote: | looks like a phantom grip... |
Thats what their lawyers said to!!! _________________ 77.5 Porsche 924/4.9L cadillac swap
chad-tanner
Posted: Mon Aug 04, 2008 2:23 am Post subject: |
Lizard wrote: | technically a phantom grip unit iirc. |
Is there anyone here running a phantom grip diff conversion? _________________ 77.5 Porsche 924/4.9L cadillac swap
Posted: Mon Aug 04, 2008 3:12 am Post subject: |
Big secret, so don't tell anyone, but.. - "try the search function". _________________ "..it's made in Germany. You know the Germans always make good stuff."
simsport
Posted: Mon Aug 04, 2008 9:48 am Post subject: Phantom Grip |
I am. Works well, not as well as a proper ZF plate type but not bad. I have heard the stories about these units but as long as you do the prep work its ok. Works well as locker at launch but not as good when unloading wheels in corners.
Cheers
Simon _________________ Blown is always best! |
wombat
Joined: 07 Jun 2008 Posts: 422 Location: Melbourne, Australia
Posted: Tue Aug 19, 2008 10:56 pm Post subject: |
Question: Was LSD an option with manual cars and standard on autos? This is for some reason what I thought but I dont know why I thought this. _________________ 1977 924 2.0 Auto |
Posted: Wed Aug 20, 2008 1:39 am Post subject: |
I've never heard of an auto with LSD. The only gear box that even offered it as an option was the snailshell. I don't believe the pre-944 audi-based 924 gearboxes ever had LSD as an option from the factory. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Wed Aug 20, 2008 2:39 am Post subject: |
Recall reading something like that in the haynes. More BS than wishful thinking.
Am positive that if you jack your rear wheels up, handbrake off, trans in N, and rotate one wheel the other will turn in the opposite direction, indicating an open wheel diff. With a LSD both wheels will rotate the same way.
FYI the 924 and 944 autos are essentially the same transmission, Audi/VW 087. Minor differences such as ports for the cooler but the internals are identical, and AFAIK the ratios too. The diff ratio may be taller though. |
Posted: Wed Aug 20, 2008 2:58 am Post subject: |
RC wrote: | The diff ratio may be taller though. |
Yes, this is the case, and many have reported it to be unsuitable for the 924, unless you REALLY enjoy winding out in 4th gear. _________________ erstwhile owner of just about every 924 variant ever made |
