Joined: 05 Jun 2006 Posts: 1489 Location: Ontario, Canada
Posted: Tue May 20, 2008 2:10 am Post subject: Adjustable cam gear? |
Anyone try an adjustable cam gear with the stock camshaft?
Is it worth it?
What’s the result?
Would you recommend it?
Thanks |
Rich H
Posted: Tue May 20, 2008 3:16 am Post subject: |
Pointless with standard engine bits, what would you adjust for? If you have a manufacturing problem you could tune that out perhaps, but its alot of work for no result.
IMHO of course!
Rich _________________ 1994 Lotus Esprit S4 - Work in progress...
Posted: Tue May 20, 2008 7:40 pm Post subject: |
would it be beneficial on a BAE turbo install? looking for some serious acceleration as opposed to top end speed...p.s sorry to hijack  _________________ 1979 NA
my Porsches Arse!!! |
Rich H
Posted: Tue May 20, 2008 9:00 pm Post subject: |
Again I doubt it. You may get a little bit more torque or top end, but I doubt you will notice! If it was a Twink you could play with overlap and so on, but as a SOHC you are stuck with the profile you have. _________________ 1994 Lotus Esprit S4 - Work in progress...
!tom
Posted: Wed May 21, 2008 2:28 am Post subject: |
The motivation for an adjustable cam gear is often to set the cam timing back to the stock value after machining the head or block (as appropriate) to increase compression. A light skim of either surface to get it back to true is not going to make much of a difference to the timing. _________________ 78 924 NA
5-lug |
Raceboy
Posted: Wed May 21, 2008 5:07 am Post subject: |
My suggestion: if cam tuning is required, use adjustable cam pulley, tune it and then have new groove machined to stock pulley in the correct location.
It's not good to have another potential failure place (bolts on the pulley). _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
Posted: Wed May 21, 2008 11:04 pm Post subject: |
| From what I read, adjustable cam gear is design to move the power band to get more low end or top end. Since the 924 power band with the 4 speed tranny is low, I was hoping to move it up a little bit to hopefully get better performance. |
Rich H
Posted: Thu May 22, 2008 12:30 am Post subject: |
Maybe, but your cash would be better spent elsewhere... Like a 5 speed box perhaps!
Adjustable cam gear and Franco cam gear are different beasts entirely.... Adjustable cam gear is traditionally for correctly timing wild cams. If its possible to alter power bands I would be very interested but I don't think it will work... _________________ 1994 Lotus Esprit S4 - Work in progress...
bass gt
Posted: Thu May 22, 2008 3:41 am Post subject: |
| Rich H wrote: | | If its possible to alter power bands I would be very interested but I don't think it will work... |
Rich,
In my experience with my hotter cam, the Piper vernier cam wheel was good in dialling in the ideal cam timing. by swinging the vernier 3degress either side of 0, there was a noticable change in the power characteristic. However, where the bottom end power increased, there was a drop in top end power, and vice versa. Whether this can be replicated on a stock cam i don't know, but as an aside, every car in theUK 924 championship runs a Piper cam wheel. Take from that what you will. And raceboy's comment about the risk of the wheel failing/shifting out of true is a non event on the Piper wheel.
Rich H
Posted: Thu May 22, 2008 6:38 am Post subject: |
Cool.
I'll have a play then I bought one for my planned engine upgrade and fitted it as it was shiney. I'll have a play when I get a chance. Its a piper one so only +/- 3 degrees unless all the screws fall out... _________________ 1994 Lotus Esprit S4 - Work in progress...
Posted: Thu May 22, 2008 10:06 am Post subject: |
keep us informed rich H ! _________________ 1979 NA
Rich H
Posted: Thu May 22, 2008 5:22 pm Post subject: |
I'm on hols for 2 weeks as of Tues, and I haev a bit of a bodywork issue at the moment.... Bugger.... _________________ 1994 Lotus Esprit S4 - Work in progress...
Posted: Thu Sep 18, 2008 1:44 pm Post subject: |
rich..any progress on the cam gear? _________________ 1979 NA
Rich H
Posted: Thu Sep 18, 2008 5:12 pm Post subject: |
Nope, its fitted but I have't played with it yet. Been busy with everything else!
I'll try and remember and have a go next week. _________________ 1994 Lotus Esprit S4 - Work in progress...
