944 brake swap
friggin
PostPosted: Wed Sep 02, 2015 2:30 pm    Post subject: 944 brake swap Reply with quote
hey guys what all do I need to have and do for the 944 brakes to work on my 79 924? I tried to read a post but all it did was confuse me.
I'm new to these cars so if someone has a kit I could buy that would be awesome!
Won't be doing this till next summer but I'm wanting to get an idea of the work involved and price range to be expecting. Thanks!
1979 924 stocker soon to be autocross beast
PostPosted: Wed Sep 02, 2015 2:57 pm    Post subject: Reply with quote
http://www.924board.org/viewtopic.php?t=25795
It's all in there.
Basically, front uprights, hubs, rotors, calipers, new flex hoses and pads. Rear caliper adapters (or the trailing arms as they are easier to swap and you can service the bearings and bushings while you're in there), calipers, rotors, new pads/rotors/flex lines. E-brake cable is different as well.
The 79 is kinda tricky due to the way the brake hard lines are setup. So you can use your choice of 924 Turbo or 944 brake parts with the 79 turbo brake master cylinder. The other option is to replace the brake hard lines to match the 944 style brake split and use the later 924 turbo/944 master cylinder.
PostPosted: Wed Sep 02, 2015 3:16 pm    Post subject: Reply with quote
Hard to imagine what you might need other than [url+http://www.924board.org/viewtopic.php?p=218957#218957]THIS[/url]
  • Weiße (1987 924S) - Turbo S3
friggin
PostPosted: Thu Sep 03, 2015 7:13 am    Post subject: Reply with quote
Thanks guys! I didn't know those threads were out there!
friggin
PostPosted: Thu Sep 03, 2015 7:15 am    Post subject: Reply with quote
Any idea if there's a kit though? Or do you need a donor car? Because finding a donor car here isn't possible haha I bought the only Porsche in my town...
PostPosted: Thu Sep 03, 2015 8:48 am    Post subject: Reply with quote
Nope.
Come out to the PNW for a Pro Solo event and you can raid someone's parts bin.
PostPosted: Thu Sep 03, 2015 10:27 am    Post subject: Reply with quote
There's also THIS
