alexvex
Joined: 31 Jul 2006 Posts: 420 Location: Seattle, WA (from Indiana)
Posted: Wed Oct 08, 2008 10:44 am Post subject: 86 951 Suspension for 5 lug swap |
Alright, I know this has been covered before, but I figured I'd double check with the pros one last time.
If you ignore the problem of the speedo hole, is this possible with the following?
-86 951 front brakes, spindles, hubs, struts/springs, brakes
-86951 rear backing plates, spacers, rotors, calipers, parking brake cables, hubs
-86 951 master cylinder and booster
I know I have to redo the brake lines to a front/rear bias. I also know i need to run the right wheels (will be running early offset for 944/cgt fenders/flares).
Do I need the front a-arms or can you use the stock ones?
Thanks in advance! _________________ --Alex--
1992 Porsche 968 (VW 2.5L I5 Turbo swap in the works)
1995 Audi 90 Quattro Sport (4.2L V8 Swap)
2010 Touareg TDI
Past Pcars: 80 931, 87 924S, 87 951 |
