Shaggy is Intercooled * * * UPDATE - PICS * * *
Goto page 1, 2, 3, 4  Next
PostPosted: Fri Mar 21, 2008 11:34 am    Post subject: Shaggy is Intercooled * * * UPDATE - PICS * * * Reply with quote
I am too exhausted to post them now, but I have a ton of pics and the project is done. Just getting rid of the S1 TB and pressure ducting has the car idling and sounding better. . .
Rasta Stoked.
jazz guy
PostPosted: Fri Mar 21, 2008 11:56 am    Post subject: Reply with quote
If this were the Rennlist, I would have to say something like, "This thread is useless without pics!" But... being that this is the 924board, I'll be patient and extend a hearty, "Job well done!" instead.
I like the design of your IC, and I'll be quite interested to hear how it works. I bet it feels good to see some of your plans coming together.
Have a cold one on me... and then post those pics!
Cheers, Brian
endwrench
PostPosted: Fri Mar 21, 2008 1:30 pm    Post subject: Reply with quote
This thread is useless without pics.
PostPosted: Fri Mar 21, 2008 1:49 pm    Post subject: Reply with quote
Indeed a bastard you are.
jgleano
PostPosted: Fri Mar 21, 2008 2:21 pm    Post subject: Reply with quote
ahahahha. I know what you mean... thats the typical "rennlist" reply about no pics.
Jevan Leano
1989 Guard's Red 944 n/a full turbo body conversion, 931 hood, D90's,
198O (going to be Orange Pearl) 931. MODDED
View user's profile Send private message Send e-mail Visit poster's website AIM Address MSN Messenger
PostPosted: Fri Mar 21, 2008 6:14 pm    Post subject: Reply with quote
cant wait to see some performance figures....could you do some 0-60 tests...maby a 1/4 mile ?
jgleano
PostPosted: Fri Mar 21, 2008 10:12 pm    Post subject: Reply with quote
how many hp gains should you expect when you intercool these cars??? I have no clue....i also need to get mine dynoed.
Jevan Leano
PostPosted: Sat Mar 22, 2008 3:42 pm    Post subject: Reply with quote
The first step was to relocate the battery. This was professionally done, and wow. 1 ga wire was used from the right rear to the starter (wrapped in fire sleeve and running beneath the torque tube and above the exhaust), and a 12v hot terminal was installed below the overflow tank.
Where did it go?
There it is! Optimal!
Juice, anyone?
PostPosted: Sat Mar 22, 2008 3:47 pm    Post subject: Reply with quote
OK, next you gotta assemble the ingredients.
Heat exchanger:
Engine Compartment:
Big box o' shit:
Booze Coffee:
Cool backup car to run to the store:
PostPosted: Sat Mar 22, 2008 3:57 pm    Post subject: Reply with quote
Now install the heat exchanger:
Header panel reinstalled, fastening lip painted.
Here's the heat exchanger through the grilles:
And from the engine compartment:
And from below:
Nice!
PostPosted: Sat Mar 22, 2008 4:02 pm    Post subject: Reply with quote
The system needs a pump, which is a bit tricky to install where I want it, mounted up to a wafer-thin box section behind the front bumper.
These inexpensive anchors did the trick:
Slap on some rubber mounts:
And up she goes. Thexthy!
That is clean. . .and mean!
PostPosted: Sat Mar 22, 2008 4:12 pm    Post subject: Reply with quote
For the water plumbing, I utilized my new favorite toy, the crimp clamp. I only used screw-type clamps at those points that absoutely needed to be able to come apart in the future.
Here is where the coolant hoses cross the main firewall:
Note the clear hose. . .my effort to monitor air bubbles, etc., in the coolant system.
PostPosted: Sat Mar 22, 2008 4:16 pm    Post subject: Reply with quote
Next we're gonna swap to a SII manifold, and hack some holes in the car for air and water plumbing.
Mmmm, nice manny!
After obtaining a SII TPS harness from Ryan, the wiring part of the upgrade was like falling off a log. . .the colors for idle and WOT are the same across all models. This upgrade alone made a huge difference in how the car ran. . .neither microswitch on my SI mani was working, largely due to oil soak on the rubber caps. I suspect this is a common condition. . .SI GUYS CHECK YOUR SWITCHES.
You feel lucky, punk?
Ow!
PostPosted: Sat Mar 22, 2008 4:26 pm    Post subject: Reply with quote
Plumbing time!
Here are the layers of tubing as they are added:
Time to add the core.
Yes! YES!
Note the killer boost controller plumbing. Love those crimp clamps!!!
PostPosted: Sat Mar 22, 2008 4:29 pm    Post subject: Reply with quote
Getting close now. I think our pump needs some juice!
Relay this downstairs for me, will you m8?
DONE!
Page 1 of 4
