Rear Coilovers for DIRT CHEAP!!
PostPosted: Thu Mar 06, 2008 2:35 pm    Post subject: Rear Coilovers for DIRT CHEAP!! Reply with quote
Saw this the other day, but thought it was $650 per side, but no... It's for both sides!
http://www.ground-control-store.com/products/description.php/II=749/CA=159
PostPosted: Thu Mar 06, 2008 3:08 pm    Post subject: Reply with quote
mmm... looks nice...
Are all 924/944/968's the same with respect to this??
PostPosted: Fri Mar 07, 2008 12:42 am    Post subject: Reply with quote
Interesting. You buying, Flosho?
My first thought was "Cool, easy helper springs" but then I realized if you used these you would need to re-index anyway, so might as well toss the t-bars.
My second thought was, would my steel trailing arms tolerate the load?
PostPosted: Fri Mar 07, 2008 1:19 am    Post subject: Reply with quote
eye candy is good....but are these things realy any good? i'm looking to buy fronts and rears for my car...Flosho...will you be the lab-rat for this ?
PostPosted: Fri Mar 07, 2008 1:40 am    Post subject: Reply with quote
My teammate Chris recently got a better deal; monotube, digressive valved, double adjustable race shocks for the rear from Carrera/QA2. I think they were around $200 ea ($400 for the car). Definitely cheaper than this. Only downside is you need to drill out the mounts to use a 1/2" bolt, but that's not too bad work - I've already done this on my car.
Not sure if they're threaded body, might be a small additional charge.
Raceboy
PostPosted: Fri Mar 07, 2008 1:48 am    Post subject: Reply with quote
I'd be interested in double-adjustable rear coilovers to get rid of the t-bars on the track car and fabricate something in a manner of Kokeln rear subframe. Really, I don't feel comfortable paying couple of thousand $ for it if I can make it by myself in a few days.
But so far, affordable double-adjustable coil-overs have been the hurdle.
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
PostPosted: Fri Mar 07, 2008 2:24 am    Post subject: Reply with quote
Well I'm not sure if anyone has these on their 924, Ground Control HAS been making coilovers for quite some time, and there are many other makes/cars that ARE running these with good results.
I'm just excited that the these are relatively inexpensive. There might be a better solution out there for the hard core road racer.. but for auto-x racer, you save 700 dollars on the rear.. Seems like any performance gain you give up by going with the GC setup wouldn't be worth a $700 difference.
I'm serious considering either these rear coilovers, or cgt rear flares and front fenders.
Martijnus
PostPosted: Fri Mar 07, 2008 2:25 am    Post subject: Reply with quote
wow... with the current euro-dollar rate I only have to sell one kidney for these!
no seriously... looks like a nice deal to me
rasta... good point, haven't looked where the shocks are mounted, but the more near the axle, the less they have to tolerate...
actually, when using torsion bars the arm has to be stronger than when the pressure is guided away closer to the axle..
but that's not 100% true... depends on the design of the arm...
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
PostPosted: Fri Mar 07, 2008 5:58 am    Post subject: Reply with quote
OK, dug through my emails - it's a QA2 "Proma Star" shock from Carrera, apparently. They can be had threaded body or not, single- or double-adjustable.
He found the threaded-body, double-adjustable version online for $249 ea. Not sure where.
Here's a related page from a rennlister:
http://members.rennlist.com/dan10101/chapter_20%20-%20Coil-overs%20-2-.htm
They're very inexpensive. Carrera's been in the shock business for some time.
Here's some listings from Summit Racing:
http://store.summitracing.com/egnsearch.asp?N=700+115+303797&D=303797
Not so sure about GC; I've heard mixed reviews...
PostPosted: Fri Mar 07, 2008 7:50 am    Post subject: Reply with quote
Seems like with the QA1 shocks, you have to fab your own mounting system for the lower shock mount?
Seems the GC shocks either come with the hardware, or you can reuse the stock lower shock mount bolt.
PostPosted: Fri Mar 07, 2008 9:49 am    Post subject: Reply with quote
Wouldn't reuse the same bolt. . .far different shearing forces than it was intended for.
PostPosted: Sat Mar 08, 2008 10:14 am    Post subject: Reply with quote
Jason,
The steel arms are actually somewhat preferred over the cast as the lower mounts are favorable to side-load compared to the single-point mounts of the late models cars. The only problem with early steel arms is that most aftermarket coil-overs use the larger diameter bolts from the later models. No worries, though, most speed shops will have all the parts required to make them fit (shims, etc).
The only nice-to-do item I would also recommend is to replace the torsion tube end bushings with either Weltmeister (poly-graphite) or Racer's Edge (delrin).
Skip
Paragon Products - Porsche Parts and Accessories
www.paragon-products.com
1-800-200-9366
Martijnus
PostPosted: Sat Mar 08, 2008 11:53 am    Post subject: Reply with quote
in what way will this be an improvement?
I've got some ideas which are probably the right ones...but I'd like to hear it from you all
PostPosted: Sat Mar 08, 2008 12:02 pm    Post subject: Reply with quote
Well these coilovers are the same improvement any coilover system is. You could use these in tandem with the original suspension, or you can delete the torsion bars, and go soley with the GC setup.
It allows you to adjust the ride height quickly and easily. I believe you could also set up the corner weight of the car using a coilover shock on all 4 corners. It's just overall easier to adjust the ride height and stiffness compared to the torsion bar system that comes stock.
sparky
PostPosted: Sat Mar 08, 2008 2:04 pm    Post subject: Reply with quote
Hmmm this sounds very interesting, I might get a set of these once the other suspension bits are installed..
Here is an interesting thought.. how much weight would be saved by removing the torsion bars?
Cheers,
SparkY
When the checkered flag drops... The Bull$hit Stops
1976 Euro 924 (The 945) - Full 951 Brakes/Suspension
1998 Boxster with goodies
2002 3.0 Xtype 4wd sport
