My 31 dies and won't restart until well rested. Please help.
mrgtturbo
PostPosted: Thu Feb 19, 2015 7:25 am    Post subject: My 31 dies and won't restart until well rested. Please help. Reply with quote
Please help I’m in a bad spot, I NEED my car on the road as it’s my only source of transportation at this time due to losing my wife and family car. I know its mid-winter and not the best time for a 31 to be on the road –but again I have no choice.
When I parked the car in the fall it was blowing oil into the pressure tube and smoking pretty steadily. I knew I needed to replace or rebuild the turbo at that time. When I was forced to try to put it back on the road again before it’s time. I had the same smoking problem, but now it would run for a few minutes and then shut down –unable to be restarted for a few hours.
I have since replaced the turbo and it runs quite strong –with no smoke. However, it’s still shutting down after being run for a few minutes. Doesn’t matter if it’s being driven or left at idle. I really need to figure this issue out fast for my son and I, we live outside of town and I’m now on foot. The winter here in, Maine has been BRUTAL this year and without my car I have no means to fix any of the mess we’ve been left in.
That said, I have very little money to invest at this time, and need to spend wisely. Please help me figure out what the actual problem is.
Aaron
81' 931
emoore924
PostPosted: Thu Feb 19, 2015 10:36 am    Post subject: Reply with quote
Well, sounds like it runs, so you have compression. You'll be missing either fuel or spark when it fails.
So a little more about the failure mode-- does it just suddenly shut off or does it die slowly, sputtering and coughing as it goes?
I'd say have a spare plug ready. When it dies the next time, quick, pull the plug wire off #1, stick the spare plug in it, ground it to the head and have someone crank. If you have spark, its fuel. If no spark, well, you have no spark. You can take the diag from there.
I'm betting fuel. Bag fuel pump. Clogged filter. Bad CIS distrubutor or WUR.
Let us know what happens.
PostPosted: Thu Feb 19, 2015 12:43 pm    Post subject: Reply with quote
Your car is an S2, so you may be having issues with the DITC system. I've seen some crazy stuff with DITC cars, including one where water was leaking through one of the factory welds in the bulkhead directly above the fuse block and right onto the fuel pump relay (FPR). I've seen connectors at the fuse block pushed out the back of the relay holder from the FPR being plugged in an out frequently during diagnostics.
I agree with Ed that it's most likely a fuel or spark problem, the trick is to isolate which, and then figure out why.
Some other possibilities:
Fuel Pump Relay can cause all kinds of problems on DITC car. Corrosion on the terminals, terminals coming loose from the relay holder, relay heating up and closing the circuit, relay starting to fail in general, etc. You can fairly easily eliminate the FPR as the culprit by TEMPORARILY jumpering pins 30 and 87 at the relay holder. This will cause the fuel pump to run constantly, so it is by no means a fix and unsafe to operate on the road, but you can at least determine if the car will stay running with the jumper in place. If it does, good chance the FPR is your culprit. It will also force you to carefully inspect the relay holder while you're under there.
Once you've eliminated FPR as a culprit, the very next thing I would do is confirm that the DITC connections are working correctly. See this thread: http://www.924board.org/viewtopic.php?t=28790 and look for the section on DITC.
Once you've confirmed that the DITC harness is dry and properly seated, you should go on with the rest of the diagnostics.
This is no time to haphazardly guess. Start at the top of the diagnostic listed in the aforementioned thread, and be methodical. Take notes. Don't skip any tests, even if you think you know something is working. You should assume that nothing is working the way you think it is. Use the diagnostic to methodically rule out potential culprits one by one.
Hope this helps.
PostPosted: Fri Feb 20, 2015 2:03 am    Post subject: Reply with quote
Sounds like its starting on the CCV but has inadequate cold start enrichment to stay running. . .just another idea. I'd check fuel pressures, and smoke the intake for vacuum leaks.
mrgtturbo
PostPosted: Fri Feb 20, 2015 10:24 am    Post subject: Reply with quote
Thank you, everyone. Though I was TRULY hoping to work on her today -life had other plans for me. However, I do not foresee anything holding me back from putting time in to sorting this issue tomorrow.
I'll be sure to check back in after I do.
Many thanks to all who have responded.
Aaron
81' 931
mrgtturbo
PostPosted: Sat Feb 21, 2015 2:22 pm    Post subject: Reply with quote
Been getting help from Dan and Vaughan -much thanks.
Ed, the car just shuts down -without complaint. It's like, "I'm done."
So far it's been discovered that once stalling the spark is gone. The DITC connections at this point seem clean and fine, as does the fuel pump. Tomorrow it's in to the steering Column and then searching for grounds.
If anyone has or could link me to a 'map' of ground locations that would be wonderful and greatly appreciated -as I really do not know where I'm looking yet. Though I was told there is a fairly large cluster up under the dash (which sounds to be interesting). :/
81' 931
emoore924
PostPosted: Sun Feb 22, 2015 3:43 am    Post subject: Reply with quote
Could it be simple/lucky as a bad ignition switch?
mrgtturbo
PostPosted: Sun Feb 22, 2015 4:24 am    Post subject: Reply with quote
I just found there to be a small crack in the bottom of the plastic in the switch. Is it possible this is the cause?
*Edit. I posted a photo on FB.
Aaron Bonneau
Maine
You'd know my profile if you saw it. LOL
81' 931
PostPosted: Sun Feb 22, 2015 4:38 am    Post subject: Reply with quote
Yes, common failure. Every car I've hsf required that switch to be replaced.
mrgtturbo
PostPosted: Sun Feb 22, 2015 4:50 am    Post subject: Reply with quote
hsf?
81' 931
PostPosted: Sun Feb 22, 2015 7:24 am    Post subject: Reply with quote
had similar failures...
sounds like the culprit,
mrgtturbo
PostPosted: Sun Feb 22, 2015 7:34 am    Post subject: Reply with quote
Thank you.
Unfortunately it wasn't. Though after noticing at a little brown at the base of the crack I decided to investigate further -and it came apart in a 1/2 dozen or more pieces. :/ Oh-well, I had already decided it needed to be replaced. But we confirmed this was not the actual problem after jumping the ignition.
Still stumped.
81' 931
SlayerSST
PostPosted: Sun Feb 22, 2015 4:28 pm    Post subject: Reply with quote
If your fuel pump relay is stuck or broken it will cause the no spark problem.
Remove it, give it a few taps on its side and re-install.
You can hear a click from the relay when the key is put on the start position.
You can also feel the relay click if you put your hand over it.
Clbmkr1
PostPosted: Wed Mar 18, 2015 2:55 am    Post subject: Reply with quote
Aaron,
I had the same issue with 1980 when I bought it. It would always start, but periodically die. It sometimes would start within minutes. Other times, after several hours I would have it towed home. The it would start.
Turned out to be a short in the distributor. I bought a new one and have had no issues in three years.
Jim Baldwin
1980 931
2013 Lincoln MKZ
2013 Ford Escape
PostPosted: Thu Mar 19, 2015 12:27 am    Post subject: Reply with quote
Clbmkr1 wrote:
Aaron,
I still contend that the issue with Aaron's car is something like this, and NOT the DITC.
