esky365
Posted: Tue Dec 25, 2007 9:11 pm Post subject: strut brace - pattern part? |
I have just been looking on e bay for a 924 strut brace with no joy. Is there another car that can provide a strut brace that will fit the 924?
It will give me more options perhaps!
thanks _________________ Steve
1979 2 litre
4 speed |
Posted: Wed Dec 26, 2007 4:22 am Post subject: |
Steve, unless you install solid strut top mounts (or camber plates), the brace will have no effect. . .and maybe not even then. _________________ Toofah King Bad
Chrenan
Posted: Wed Dec 26, 2007 5:25 am Post subject: |
I'm pretty sure everything needs to be solid (top mounts and lower bushings) before a strut brace is needed. _________________ 1987 951 - M193 Version for Japan |
Posted: Wed Dec 26, 2007 10:15 am Post subject: |
Yeah, and like I said, maybe not even then. . .it might be that the unibody and crossmember aren't subject to that type of flex. I have seen a few track prepped 951s and never seen one with a strut brace. _________________ Toofah King Bad
Chrenan
Posted: Wed Dec 26, 2007 11:21 am Post subject: |
Could be true, I've actually heard the 924/944/968 chassis is more prone to flex at the bottom of the shock tower structure (the area near the cross member).
Thus, this type of brace is more usefull:
http://www.rsbarn.com/968chassisbrace.html
Of course, it doesn't provide any bling factor when you open your hood. _________________ 1987 951 - M193 Version for Japan |
Posted: Wed Dec 26, 2007 12:12 pm Post subject: |
That's an interesting part, but it seems that it would only prevent bushing deflection. I doubt the boxed aluminum x-member is compressing or stretching under cornering loads. . . _________________ Toofah King Bad
