Benino
Joined: 30 Jan 2003 Posts: 505 Location: Vista, CA (San Diego County)
Posted: Sat Dec 22, 2007 6:25 am Post subject: home made short shifter |
I'm planning on shortening the shift lever that clamps onto the selector shaft that comes out of the transmission to make my own short shifter. Does someone know the measurement on the short shifter from the center of the selector shaft to the center of the rod that connects to the rest of the linkage? I don't want to make mine too short, but if I don't make it short enough it won't be worth the work.
Heres a picture of the part and measurement I'm talking about. Can someone measure this distance on the short shifter kit? thanks.
_________________ 1980 Porsche 924 N/A USA
1980 Porsche 924 turbo USA
1987 Porsche 944S USA |
Posted: Sat Dec 22, 2007 11:27 am Post subject: |
Dont forget, you can also move the connecting shift rod (#8) higher on the gearshift for a shorter throw.
And you might want to shorten the side to side throw by lengthening this.
haroldk
Joined: 24 Nov 2008 Posts: 171 Location: St Paul, MN, USA
Posted: Fri Dec 05, 2008 8:06 am Post subject: |
Mine measures out at about 15cm. It might be more like 15.2cm, but 15cm is pretty close. |
Posted: Fri Dec 05, 2008 9:13 am Post subject: |
Hope it works I made a short shift handle a nice one Ill have to post a pic sometime. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
haroldk
Posted: Fri Dec 05, 2008 9:52 am Post subject: |
Man, I read that date wrong. Somehow, I thought the last post before mine was from 11/22/08. |
Posted: Fri Dec 05, 2008 10:14 am Post subject: |
Aye, indeed it's an oldie but a goodie. _________________ "..it's made in Germany. You know the Germans always make good stuff."
Posted: Fri Dec 05, 2008 6:56 pm Post subject: |
yea well maybe benino will tell us what happend or what came of it how about it benino _________________ 1979 porsche 924 Na
Joined: 05 Jun 2006 Posts: 1475 Location: Ontario, Canada
Posted: Fri Dec 05, 2008 8:41 pm Post subject: |
It is about 2”3/16 or 5.6 cm.
I attempt the same last summer, I cut ˝” and it was a bit to much because the selector shaft connector couldn’t clear the top of the tranny be about 1/8".
Let us know the result and how much did you cut. |
haroldk
Posted: Fri Dec 05, 2008 10:22 pm Post subject: |
924-76 wrote: | It is about 2”3/16 or 5.6 cm.
Cripes, I guess that shows how out of it I was when I measured. I offset the tape to 10cm to make it easier to center and forgot that when I posted. Although I suppose somebody making one 15cm long would probably notice that right off the bat... |
Posted: Sat Dec 06, 2008 5:08 am Post subject: |
The short handle i made is kind iof like a pistol grip though theres no finger grooves its more like a oblong short shaft . _________________ 1979 porsche 924 Na
